Fabio 2
Obs: Sorry for possible errors ... I used the google translator.
Hello.
I migrated from HC2 to HC3. At HC2 I had a generic scene that was called by several others to send me a message on the telegram.
Example: Someone touched the campaign, I received a message on Telegram: "The campaign has been activated". The door was opened, I received a message "the door was opened".
It used a global variable in which the main scene determined the variable telegram and, after that, the generic scene that sent the message to the telegram was called.
However, with HC3, this scene stopped working.
I made some changes to the LUA code, but I can't get the message on the telegram.
Example changes: I changed "fibaro: getGlobalValue (" Telegram ")" to "fibaro.getGlobalVariable (" Telegram ")"
The error message I get is:
[DEBUG] [SCENE54]: 400
[DEBUG] [SCENE54]: {"ok": false, "error_code": 400, "description": "Bad Request: message text is empty"}
I put one more message in this code to see the value of the variable Telegram and url, and both are not reset.
fibaro.debug("URL é", url)
fibaro.debug("MSG é", msg)
From the commands above I can verify that the variables are with the values I want.
Please, could someone guide me where I was missing the LUA code below? Thank you.
14 answers to this question
