"Stair switch" how to write a scene
Alexxxx
Hello.
Please help me write a scene for two wall switch`s.
I`m using two NEO Coolcam light switches. It is impossible to connect them like a "stair switch" so i have to use scene (Associations won't work too).
The goal is to use switches like "stair switches" - turn on with one and turn off with second.
I`m useing HCL.
1 hour ago, Twannie said:
you can only  do that with multiple block scenes I think
bingo!
..but i am bad expert in Fibaro block. fibaro block always get on one's nerves me :)
Witam
also two neo and also up/downstairs lights
never use assoc
My HC2  used VD now HC3 also use VD/Qa
just syncing two switches
it’s very easy
If you are new to block scenes, have a look at the examples on vesternet.com
Some logic that may help:
If the button is pushed AND light is off THEN turn it on
If the button is pushed AND light is on THEN turn it off
Make these two scenes and apply them to both switches
  • I have made some scenes already but i have problem to make this one.
    Question to your example : how to make "if the button is pushed...."?
    All i can select for the switch is:
    Switch = on/off or different from.
    Something like this?
    If tonumber(fibaro:getValue(yourlightnr, "value") >0 then
      turnoff
    else
      turnon
      turnoff
    else
      turnon
    HCL. blocks only
    With multiple block scenes, you can save the light state in a global variable called "LightState". How to create a global variable is in this guide
    Both your on and off scenes should be set to trigger when the switch state is changed ie  "different from" if a toggle, or "on" if a pushbutton...but only one scene will create any action, based on the IF value of the global variable.
    Now, don't forget to include in your scenes to also change the value of the global variable to match the action you just took.
    Start simple. Create 1 basic scene for 1 switch and once you have that working, expand it. Your two scenes should like this:
    The on scene:
    (CoolCam1==toggled OR
    CoolCam2==toggled )AND
    (I do not have a coolcam, so can't confirm above syntax)
    LightState==off THEN
    YourLight = turn on AND
    LightState = on
    The off scene:
    LightState==on THEN
    YourLight = turn off AND
    LightState = off
    All scenes are set to "start when home centre starts" and "active scene".
  • Sorry for late response.
    I`am not able to write this scene.
    I cannot think of how many scenes i should write and what they should look like.
    You wrote:
    "Start simple. Create 1 basic scene for 1 switch and once you have that working, expand it. Your two scenes should like this".
    How many scenes there should be total ? Two ?
    "The on scene:
    LightState = on
    The off scene:
    LightState==on THEN
    LightState = off"
    I have tried to write those two scenes for "ON" and "OFF" from your example but they don't work properly. Lights are flashing on and off all the time.
    I have added predefined variable "active and inactive"
    (witch i don`t now how they work) what do they do in these scenes ?
    /monthly_2020_10/image.png.d93dbe3fcb203c3f64e09b616779cdec.png" />
    First of all the only choice i have got for Neo coolcam (called here "przedpokój światło" for light switch one and "przedpokój światło 2" for light switch two) are:
    =, not equal and W
    and ON or OFF.
    So now "toggled" to choose
    I cannot think of how these scene should look like, please help.
    Witam
    can you simple create two scenes
    1 scene like
    If swiatlo1 == ON
    then
    swiatlo2 set ON
    2nd
    if swiarlo2 == ON
    then
    swiatlo1 set ON
    dzieki!
  • This were exactly first scenes i wrote:
    if swiatlo1 == ON
    then
    swiatlo2 set ON
    2nd
    if swiarlo2 == ON
    then
    swiatlo1 set ON
    and
    if swiatlo1 == OFF
    then
    swiatlo2 set OFF
    2nd
    if swiarlo2 == OFF
    then
    swiatlo1 set OFF
    those scenes made my light turn on and off all the time. I had to turn those scenes off.
    Edited by Alexxxx
    The ideas are already above.
    A scene with:
    if switch1 then toggle light1 (if on then off, if off then on)
    And an other scene with:
    if switch2 then toggle light1 (if on then off, if off then on)
  • The only choice i have got for Neo coolcam is:
    =, not equal and W
    and ON or OFF.
    /monthly_2020_11/image.png.6a81eefcc69332288edbb2c939ccd589.png" />
  • Thanks for help.
    There is only one light and two switches operating this light.
    Switch one called "przedpokój światło" and Switch 2 called "przedpokój światło 2"
    So how many single scenes ?Two ?
    /monthly_2020_11/image.png.af64b5d1902068994d30f30a31391544.png" />
    and
    Those scenes don't work properly. Sometimes you have to push the switch two times.
    Edited by Alexxxx
