TCP Quick App with login and password
sergiobaiao
Hi there,
Can any of you help me adapt the sample TCP.fqa (TCP Client Quick App) so it has a login and password sent while connecting?
I used to have a VD in HC2 that, when clicking on the VD button, it would connect to my device, send the login and password, wait for the "telnet" prompt and then send the command. I really need this working on HC3, but i'm not able to get it working by myself.
Please help me
6 answers to this question
11 hours ago, sergiobaiao said:
Hi there,
This is a start. It can still have some issues with your specific device.
Configure quickAppVariables for ip and port and a good test that the net.TCPSocket also worked with the
(It's quite useful to develop in a real IDE when debugging socket protocols....)
The code is actually quite small
  • thank you very much. I'll test it and post here the results.
  • I tried to modify the QA to make it a little "more flexible" but it didn't work. I've added 3 variables to it, login, password and LID (being the ID of the Lutron Lighting Zone).
    As this will be controlling a Lighting zone, there should be buttons for both ON and OFF at least, maybe a slider if it's a Dimmable zone. So what i this was add this to onInit:
    self.login = self:getVariable("login")               -- "lutron"
    self.password = self:getVariable("password")               -- "integration"
    self.lID = self:getVariable("LID")               -- "41"
    then i created a copy of the "commands" variable and tried to make it work with my created variables, and that thrown an error:
    local commandsON = {
      250,"W:".. self.login .."\r\n","R:(.*)",
      250,"W:".. self.password .."\r\n","R:(.*)",
      250,"W:#OUTPUT," ..self.LID.. "41,1,100\r\n",
      250,function(cmds,n,res)
        quickApp:updateView('status','text','OK')
    local commandsOFF = {
      250,"W:#OUTPUT," ..self.LID.. "41,1,0\r\n",
    -- This would be a dimmer like command, setting the zone to 30%, reading the value from a slider
    local commandsDIM = {
      250,"W:#OUTPUT," ..self.LID.. "41,1,30\r\n",
    Can you help again to adapt it?
    You can't use 'self' outside the QuickApp functions
    Especially this won't work
    I would create the table in the QuickApp:login function that hands it to doCommands(...). There you have self defined.
    You could then also have other buttons that sends other command lists to doCommands() to do other stuff.
    Updated the example by moving commands into login()...
    Hi Jan,
    In the QA file you sent me, does it keep the connection established all the time? Or it connect only when sending the command?
    The last ”command” closes the socket
