Question: variables will update during script?
Redeemer
Hi there,
I have a little question about variables declaration. Sorry if this question is already elsewhere but I was unable to find it.
At the beginning of the script I declare a variable calling a sensor with something like this:
myvariable = fibaro:getvalue(*ID*, "value")
and I use it thorough my script.
If the sensor change status during the script (let's say the variable is linked to a motion sensor, that from breached switch to safe because it doesn't see any movement anymore) does the variable update itself or I have to call again for a "getvalue" to force it to update?
  • Answer by myself: no, they will not update themselves automatically. you have to call them again to update.
    Changing question: there is a way to update a variable every time the sensor linked change state?
    @Redeemer You can update a global variable with the actual status. But in your code you then still have to react on the changed global variable.
    Maybe explain what you are trying to achieve? Many things are already solved on the forum.
  • Hi @SmartHomeEddy ,
    Thanks for the help, I imagined that.
    I'm doing a little script that leaves the garage door open "while" it sees movement inside it (informations got by 2 motion sensors).
    I get the value from these sensors at the beginning of the script and convert them into variables (to remember them better), and I noticed that those variables does not change unless you call them again when the sensor change status.
    This is it, without entering into details. If you need more of them I can post the entire script here.
    @Redeemer I use a script that leaves the light on, as long as there is movement by two motion sensors. That sounds the same?
    Edited by SmartHomeEddy
  • @SmartHomeEddy yeah exactly, except that I have to leave also my garage door open, but that should not be too difficult to implement.
    Can you share it? I’m still a noob in LUA scripting.
    Thanks!!
    This is my ACTION part:
    This is my DECLARATIONS part:
    ehm, i think Radeemer is looking for HC2 solution, not HC3 (and on HC3 in scenes one can additionally use get/setSceneVariable)
    Have you figured out where they store the scene variables?
    I had the same sort of script on my HC2, but can’t find it on the forum. Maybe I never uploaded it. I found something a bit simular:
  • Thanks to all of you guys, I have looked at the other forum post but it's pretty complicated. I have done something similar but with a lot less lines of code. At the moment it's working fine, will let you know if there will be troubles.
    @SmartHomeEddy since you have HC3, can you tell me how it works? I have a couple of Sankotronic scripts and other ones made by myself, do you think I can have some troubles with that?
    do you mean the script that keeps the light on during motion?
    No, I mean the HC3 entirely. I have heard, some time ago, that there are some troubles with some VDs (like the one for NetAtmo weather by Sankotronic).
    @Redeemer The HC3 works fine. But second party scripts are still to be developed. The VDs won't work on the HC3. Sankotronic hasn't build HC3 scripts of Quickapps, so if you rely on his scripts or VDs, try to find alternatives of build them yourself. I don't use Netatmo, so I don't know if that works ok. There are Quickapps for Netatmo.
    There is a lot of development on this forum. Without that, I wouldn't have bought the HC3, but that also counts for the HC2 I still have.
    Thanks a lot for your analysis. Very helpful!
