Secure thermostat and Qubino Flush on/off thermostat
Slim! domotica
Hi All of you,
Does anybody have an idea how to connect a secure SRT321 and a Qubino flush on/off thermostat can be coupled?
The goal is that the SRT should be the one to set the temperature and the Qubino should switch the electrical floorheating.
Meanwhile the Qubino sensor should be able to measure the reached temperature.
So f you set the temperature on the SRT to, for example, 25 degrees, it should switch the Qubino to on, if the measured temperature by the Qubino sensor is below the 25 degrees. as soon as the Qubino sensor measures 25 degrees it should switch of and ofcourse when the floor temperature comes below the 25 degrees it should switch on again.
