Frot 0
Hello, I have an empty QA device (temperature device). What's the easiest way to set the value (temperature) using HTTP call (from outside HC3) to the API? Or do I need to provide some method in QA that i.e. the `callAction` REST API will use? I'd prefer to have empty QA and do everything via REST API.
Edited by FrotLink to comment
1 answer to this question
