JoergiNRW 1
Hi @all!
In the last weeks I installed a new Walli Dimmer as replacement of the older normal dimmers from Fibaro.
After some time after I switched the lamp on, the brightness changes frequently. Yes, there is a LED bulb installed, that is dimmable. And I also have installed a Fibaro Bypass, so that the LED really can switch off.
It worked perfectly for some years. But now with the newer (fancy ?) Walli Dimmer it does not function properly.
I forced the recalibration with Parameter 159 set to "2 - force auto-calibration with FIBARO Bypass 2". Nothing changes. ?
It´s horrible when the light gets brighter and then darker again.
Does there exist any solution for this??
Thanks and regards,
Jörg
5 answers to this question
