Generic Fibaro HC3 Alarm system
ChristianSogaard
Hi Luabuilder :-) Sharing is Caring
I have see a lot of talk using Fibaro HC3 for Alarm system. I love the idea - i want that, so i tried to describe what a Generic Alarm system should be build of.
Several people already tipped in with things they made og thoughts they have, issues they identified.
Why invent the wheel when great tuff already has been made.
@jgab has created the
 and
- All-in-one QA framework for HC3 - this can be used for arming and disarming the alarm - An example is provided
@10derand @JcBorgs  described issue about HC3 is missing the  "disable alarmExclude" -  a “pre-check” for sensors before arming ALARM is needed
What a good way to solve this - I way thinking of enhancing the doorstatus QA (below) ?
And @FBerges already shared
of an alarm system
@Mateo created a Siren
And probably many more worked on their own solution to create a ALARM SYSTEM.
Please tip IN if there is elementary features ? - that is missing for a generic HC3 Alarm!
How would you structure this? ? - ONE Quick APP with everything, Variable for customising? or a QA with Scenes and
Another useful idea that could be used, is the status for open windows and doors.
This QA changes the Color in the matrix Bulb when a door or windows is opened.
 @10der learned me about getting the sensor possibilities with
Perhaps some of the forum experts could create some overall structure and point the learners in right direction? ? ?
Desired Functionality
In case of alarm not armed
Geofence
•    Ongoing control - have all users left the house? Message on Telephone (s) that the house is empty and the alarm is not active
For ARMING the Alarm
•    Message on Telephone (s) about which windows are not closed.
  • Message format Section, room, Sensor
  • Message on Telephone (s) about which doors are not closed
  • Message on Phone (s) When alarm is active and which Zone.
    • Message could be Fibaro APP push, or Telegram
    • Delay to get out the door
  • Use a Keypad like Matrix for ARM - ala triple cut on one button and subsequently double click on another.
      is already made by @Jgab in
  • Use Fibaro APP for ARM
  • LED/Bulb for show Status ARMED – I will probably use MATRIX ZDB LED in the perimeter to changes to RED
By Disarm the Alarm
  • Message on Phone (s) alarm is deactivated and if other Zones are active
  • LED/Bulb for show Status DisARMED – I will probably use MATRIX ZDB LED in the perimeter to changes to GREEN, but could be a HUE Bulb
  • Use Matrix for DisARM - like triple cut on one button and subsequently double click on another.
    • This feature is already made by @jgab in
  • Use Fibaro APP for DisARM
For Alarm ACTIVE
  • Internal sirens are triggered
  • External sirens are triggered
  • Light with alarm status, flashes 1 Hz
  • SONOS speech - sound.
    • Could be by using the Quick App -
  • Message on Telephone about which device has triggered alarm - Section, room, Sensor
I have an alarm example with ER4 that solves a couple of the problems
  • It triggers when a zone is activated and then checks the devices that are part of the zone if someone is breached and if so cancels the alarm and notifies the user. Because it triggers on the zone being activated it doesn't matter if a users enabled the alarm with the UI/app or with a Lua rules. It depends on that there is a delay set between the zone being activated and it actually becoming armed.
  • It can notify you the name of the breached sensors when you try to activated the alarm with this add-on. <
  • It could be complemented with a rule checking if a sensor is breached between being activated and actually armed. Now the check is done only when activated.
    Thank you for you collaboration - I had the feeling that ER4 is very powerfull ?  for alarm system.
    - I would be awesome with an Rule example "if a sensor is breached between being activated and actually armed"
    The rule in the linked example look like this
    The ER4 sends out a trigger of {type='alarm',property='willAlarm'} when a zone is about to be armed. The trigger also contains the ID of the zone and the number of seconds until it arms.
    In the example we check if all the devices are safe and then notify the user that the alarm is about to be armed in X seconds
    If any device is breached we instead notify the user that there are breached devices and cancel the alarm.
    The rule could be modified to do other things if needed...
    The add-on I linked to retrieves the name of the beached sensors in the zone and sends them in the notification.
    ER4 treats zone 0 as the whole house (all defined zones)
    1 hour ago, ChristianSogaard said:
    com.fibaro.windowSensor com.fibaro.doorWindowSensor  com.fibaro.doorSensor
    you do NOT need to use
    /devices/hierarchy
    cuz
    local doorWindowSIds = fibaro.getDevicesID({isTypeOf = "com.fibaro.doorWindowSensor"})
    local motionIds = fibaro.getDevicesID({isTypeOf = "com.fibaro.motionSensor"})
    already include hierarchy
    for example.
    I have
    /monthly_2020_11/image.png.cb201103bd1913b61db1928edda7b80f.png" />
    call
    as you can see Type is motion but my foibaro sensor is
    • type: "com.fibaro.FGMS001v2",
    • baseType: "com.fibaro.FGMS001",
    so trying
    yay!
    but if you wanna learn
    hierarchy
    you can playing with my code
    function findType(hierarchybaseType)
        local current = hierarchy
        if current == nil then
            return nil
        elseif current.type == baseType then
            return current
        else
            for _,v in pairs(current.childrendo
                local data = findType(v, baseType)
                if data ~= nil then
                    return data
        return nil
    function collect(current)
            if v.type then
                print(v.type)
                collect(v)
    local tree = api.get("/devices/hierarchy")
    local result = findType(tree, 'com.fibaro.motionSensor')
    collect(result)
    --print(json.encode(result))
    local result = findType(tree, 'com.fibaro.doorWindowSensor')
    collect(result)
    -- print(json.encode(result))
    Edited by 10der
    I think the alarm model in HC3 makes sense. We put devices in alarm zones and we arm zones. (On the HC2 we arm devices).
    The issue may be that we can't put any device in an alarm zone. It needs the be a derivative of com.fibaro.securitySensor, like motionSesnor, windowSensor etc. I think it would have been better if it was a device "interface" but there needs to be some protocol for devices to signal that they are breached or safe.
    However, it's not that difficult to make a QA wrapper for something else like a binarySwitch etc.
    /devices/hierarchy
    cuz
    for example.
    I have
    call
    so trying
    yay!
    hierarchy
            return nil
            return current
        else
                if data ~= nil then
                    return data
        return nil
            if v.type then
                print(v.type)
                collect(v)
    collect(result)
    collect(result)
    This is great stuff for learning - thank you very usefull ?
    On 11/15/2020 at 1:06 PM, jgab said:
    The rule in the linked example look like this (the "pre-check")
    I think it was my example, but I'm fine with @10der getting the credit :-)
    Even better may be to print out the hierarchy - makes it easier to see the descendants of com.fibaro.securitySensor
    I'm sorry @jgab for sure i dont want to disrespect anyone or give wrong credits ?.
    I was looking after an example to show the hierarchy Tree - Thank you for your example here.
    I tried creating a new Quick App and putting it there - my QuickApp crashed. I also tied putting into a scene and calling the printTypes function.
    could you give some hint how I should use your example?
    Sorry a "local" was added to the function by mistake
    I get the structure now ? - and the example @10der provided I can search for attributes in the different sensors.
    /devices/hierarchy
    cuz
    for example.
    I have
    call
    so trying
    yay!
    hierarchy
            return nil
            return current
        else
                if data ~= nil then
                    return data
        return nil
            if v.type then
                print(v.type)
                collect(v)
    collect(result)
    collect(result)
    So this
    gives the same result as the old code - at least what I can test.
    So just by using {} will put the result into a table direct ?
    10 minutes ago, ChristianSogaard said:
    So this
    Are you doing a "alarm system" that is not using the HC3 alarm partition/zone concept?
    Because using the HC3 model all sensors that are part of a zone/partition can be fetched from the zone/partition info.
    In practice there is no need to list all devices of a particular type as the only relevant devices are the ones added to the zones/partitions.
    and you can check if a zone is breached or safe
    My goal is to reuse as much as possible from the original HC3 Alarm system. My first goal is to have PUSH messages, when arming, about door & windows not closed. And for an Alarm breach a push message for which zone, device has breach
    So my point is that you don't need getDoorSensors(), because you have the zones and the devices belonging to the zones.
    If you list all the door sensors you still need to find out what zone it belongs to and if that zone is armed/about to be armed.
    Better then to trigger on a zone about to be armed and check whatever devices belong to that zone if they are breached.
    So
    Gives me my 3 zones
    • What is the 200 Value returned?
    • and can I use a command like fibaro.getDevicesID({isTypeOf = "com.fibaro.doorSensor"}) to get my partitions ? - i dont see it the hierarchy QA, because it end with a crash
    [15.11.2020] [15:55:23] [DEBUG] [SCENE129]: Alarm ZonesTypes 200
    [15.11.2020] [15:55:23] [DEBUG] [SCENE129]: Alarm ZonesTypes [{"id":1,"devices":[270,272,274,276,278,280,282,284,286,288,290,292,294,296,298,300,302],"breachDelay":5,"armDelay":0,"name":"Perimeter Zone","armed":false,"breached":false},{"id":2,"devices":[236,270,272,274,276,278,280,282,284,286,288,290,292,294,296,298,300,302,404],"breachDelay":0,"armDelay":0,"name":"Whole House","armed":false,"breached":false},{"id":3,"devices":[270],"breachDelay":0,"armDelay":0,"name":"Outdoor","armed":false,"breached":false}]
    Examples in Lua if you don't want to use ER4 :-)
    If you want to list all devices that can be part of a alarm partition/zone you can do
    Guess fibaro uses that to populate the pop-up form when adding devices to partitions
    This is very explaining and useful, great stuff :-)
    As you probably already discovery, i'm pretty rookie for this. I for sure believe I will manage - I used to code assembler on my commodore 64, but do the math ;-) that was in 1986. I'm investing a lot of hours to learn
    I like the event runner 4 - but I installed it two days ago - so there are some learning curve ;-) like everything else here.
    For the examples you just provided - I put that in a Scene, and I am getting
    [15.11.2020] [16:15:24] [ERROR] [SCENE134]: (load):6: Assertion failed: Expected number
    I have other examples where "Assertion failed" i bugging me - WHY, I dont get it?
    I implemented ChildrenOfHue yesterday, in the whole house. My family was very happy - no of the Matrix Switches as worked since I migrated from my HC2 to HC3  more than a month ago.
    Still i have a big wish for one button support and the "thing" were dim2off=true kicks in way too early.
    How would you make EV4 to send a PUSH with devices not ready?
    Sorry, I renamed a variable in the first function.
    It should. be
    It should. be
    I'm getting an error on RULE 10 - the user is missing , I tried adding a User into the HT - but I missed the syntax.
    I did try to fin a description in the
