gps
kopek
Hello
1.Can anyone help me why GPS can't work in scenes? ... or position definition. Data connection enabled on phone. HC2 is set to refresh for 5 minutes
2.and when / how do the other members of the family appear under the "family" tab in the main panel?
thanks
5 answers to this question
  • Please login or register to see this image.
    /monthly_2020_11/image.png.828382160400deaa4ed8ab984ee23386.png" />
    - creates a location in the location panel
    - you select the device and the location when you arrive or leave
    then send a notification (you allow push messages to be received
    arrival works better than departure
    Same issue. I've seen this is going on for years....
    My GPS isn't working either, one trigger I like most... but it does not work!
    Family panel is removed for a while ago.
  • Hello
    the gps works ... i uninstalled the home center app and put the fibaro app back on. It didn't work for a while, but I was glad to see it working again. I managed to do this yesterday.
    the family panel also comes up, but only I can see it as a superuser, unfortunately the family still doesn't:
    I'm still waiting for this to see if anyone can help.
    I do have the Fibaro app installed but not working here.
    Is there a way to check in the Home Center if it recognize the GPS location anyway?
  • Yes, in the HC2 main panel, the family panel (users) appears at the bottom. Under the room. There you click and you have to give a map of when you went. Unfortunately, it doesn't work for me right now. Pretty rhapsodic, but I don't know why :(
