FGS-221 for a doorbell, for S1 not always trigger Q1
Dommel
I use a FGS-221 to ring my doorbell. Thats works fine.
But what I want, is that the doorbell not always rings when S1 (door button is pressed) is triggered.
For example: At day time I want the doorbell works normal. But when the kids are sleeping, I don't want to hear the bell, but want only get a push message.
Is this possible on a HCL??
15 answers to this question
This link says it is possible.
However the onward link describing how is broken.
Only hint i can give is that you'll need to use the switch to trigger a scene, rather than q1 directly. On the newer devices you have to use s2 for scene activation, rather than s1.
The other way to do this is put a toggle switch in series with the doorbell buzzer. This allows you to switch off the sound.
Then set the device to always send a notification when the doorbell is pressed. (Not quite what you asked for but is a workaround)
On 11/28/2020 at 2:43 PM, Dommel said:
Thanks, I will try something
You could add single relais FGS-221.
Then you could make some scene's
Example
19:00 Hour Q1 Off
08:00 Hour Q1 On.
This you can hardwire in series with you're first one. No need for S1 connection.
What more expensive, but the kids will be sleeping
Is something what @Tim__ suggested anly automated toggle switch.
Hardware
Edited by Flash
    Example
    19:00 Hour Q1 Off
    08:00 Hour Q1 On.
    Hardware
    I have make the solution from Tim_.  (Doorbel not yet silence on certain time, i think that the solution from Flash works fine).
    But for now, i start a scene when S2 is triggered. The scene switched Q1.   But the scene only start when S2 is pressed for a longer time (0,5 sec). And not with a short puls.
    how can you fixed this?
    I cannot find a parameter to shorten this time. It could also be caused by the reaction time of the HCL.
  • I have looking further. I don't think it is the reaction time of the HCL.
    When I pressed the doorbell button very short, I see that the scene [its a block scene]  "scene triggered" and than "running instance: 1", but no doorbell sound.
    When I pressed the play button of the scene very short, it do the same, but with the doorbell sound.
    When I held pressed the doorbell button (>0,5s), I see that the scene [its a block scene]  "scene triggered" and than "running instance: 1", and also with the doorbell sound.
    Is there something what I am doing wrong?
  • Already tried (also with 2sec in state of the 1sec below). same result.
    try parameter 4, 5 en 13
    @akatar,
    parameter 4 is auto delay off if I'm correct.
    If I'm correct isn't it better to remove the 58.0 "uitzetten" from the scene?
    If parameter 4 isn't auto off skip previous sentences. ?
    9 minutes ago, Flash said:
    @akatar,
    or par 13, bistable is also an option, (perhaps the better one)
    I agree
  • Parameter 4 is for auto delay off. I'am using this so the "gong" of the doorbell works always correct.
    Remove 58.0 "uitzetten, that's were I start with. Also same results.
    Par 13 I will try later. The kids are now sleeping.
  • Yes, its working.
    - Par 4 auto delay off. 0,2sec >>  so that the "gong" doorbell works normal.
    - Par 13 = 0 AAN/UIT (default) (i have now idea )
    - Par 14 = Momentary switch (first push is on, second push is off)
    - Par 5 auto delay off. 4sec >> because of Par 14. This turns off the switch automatically (no second push needed)
    Later on I will try to keep the doorbell still when the kids are sleeping. I will try this to make 2 different scene's based on time and the doorbell switch.
    Thanks for the support.
