Mismatch between Heat Controller setting and Zone setting
mihneadb
I'm a new user of the Fibaro ecosystem and I'm facing some issues. One of them has to do with controlling the heat in my home. I have setup zones - 1 per room, and each zone contains 1 Heat controller. I have a HC3 and I see there are several ways in which you can control the temperature - from the Heat Controller directly, or through Zones.
I tried working with the temp view in the website (/app/climate/temperature), but also with the mobile app through manual settings on the thermostats. Anyway, in the end I did "back to schedule for all" and my zones show up OK:
You can see Living Room set at 24C. However, if I go to the climate view under settings, the thermostat for Living Room shows up as 26C (an older value set via the mobile app BEFORE choosing "back to schedule for all").
This is really odd to me. I'm curious 1. if I'm encountering a bug and 2. what is the "recommended" way to handle temp control in HC3?
Thanks!
Mihnea
