Access to advanced parameters with Samsung Smartthings
brucje
I've just purchase and installed a Fibaro dimmer. I would like to know if is it possible to access and manage the advanced parameters to set the switch 2 channel using Smartthingh.
If yes how is it possible?
Thank you very much!
1 answer to this question
Guest JB1970
I'm in the same boat but have just moved from SmartThings to Hubitat.  For Hubitat I've got a Basic Z Wave Tool driver.  I'm sure if you search on the smartthings forum you'll find a similar device handler.  You just change the device type from your Fibaro DH to the Z wave tool temporarily and it allows you to query the parameters of the and send whatever parameters you want back to it.
