SmartHomeEddy
This Quickapp retrieves power consumption, solar production, gas usage and water flow from the Iungo Monitor, Solarpanel and Watermeter
(Child) Devices for Consumption, Production, Solar Power, Water Flow, Consumption High, Consumption Low, Production High, Production Low, Total Gas and Total Water FLow
Version 1.1 (11th September 2021)
  • Changed the Child Devices Consumption High, Consumption Low, Production High and Production Low to device type energyMeter to facilitate the new Energy Panel
  • Added automaticaly change rateType interface of Child device Consumption High and Low to "consumption" and Production High and Low to "production"
  • Changed the Main Device to device type powerSensor to show the power graphs
  • Added Net Consumption to the value of the Main Device
  • Changed the Child Devices Consumption, Production and Solar Power to device type powerSensor to show the power graphs
  • Changed the Water Flow unit text from m³ to Litre
  • Added the amount of m2 Solar Panels to the log text ot the Child Device Solar Power and to the labels
  • Changed meterreading to automatically kWh, MWh of GWh
  • Moved tarif informatie to main device log text
  • Added Meter measurement for Consumption High, Consumption Low, Production High, Production Low, Gas and Water to reset the measurements
  • Added Meter measurement Date for Consumption High, Consumption Low, Production High, Production Low, Gas and Water
  • Removed Refresh button
  • Added some extra debug information when debug level = 3
Version 1.0 (6th February 2021)
  • Now also supports Iungo Solarpanel and Iungo Watermeter
  • Added a lot of Child devices
  • Added QuickApp Variable for user defined icon Mother Device
  • Added QuickApp Variable for Solar Power m2
  • Removed calculation and storage of energy consumption of Fibaro devices
Version 0.6 (22nd January 2021)
  • Now also supports Iungo basic version
Version 0.5 (21 January 2021)
  • Initial version
QuickApp variables (mandatory, they will be automatically added with the default values):
  • IPaddress = IP address of your Iungo Monitor
  • solarPanel = true or false for use of the SolarPanel module (default is false)
  • waterMeter = true or false for use of the Watermeter module (default is false)
  • interval = Number in seconds, the Lungo Monitor normally is updated every 10 seconds
  • solarM2 = The amount of m2 Solar Panels (use . for decimals) for calculating Solar Power m2
  • debugLevel = Number (1=some, 2=few, 3=all, 4=simulation mode) (default = 1)
  • meterConsHigh = Last meter measurement Consumption High
  • meterConsLow = Last meter measurement Consumption Low
  • meterProdHigh = Last meter measurement Production High
  • meterProdLow = Last meter measurement Production Low
  • meterGas = Last meter measurement Gas
  • meterWater = Last meter measurement Water
  • meterConsHighD = Date last meter measurement Consumption High
  • meterConsLowD = Date last meter measurement Consumption Low
  • meterProdHighD = Date last meter measurement Production High
  • meterProdLowD = Date last meter measurement Production Low
  • meterGasD = Date last meter measurement Gas
  • meterWaterD = Date last meter measurement Water
/monthly_2021_02/icon-iungo-logo.png.f1a9aec9e6411b15d530df72f1a795bb.png" />
Tested with:
  • Iungo lite version
  • Firmware Rev 3683 (07-01-2021)
Download the QuickApp here (download the file and un-zip):
or Fibaro Marketplace:
How to install:
Open the Configuration Interface
Go to Settings > Devices
Click  +
Choose Other Device
Choose Upload File
Choose file from your computer with .fqa
Edited by SmartHomeEddy
The previous screenshot was with DebugLevel 1, this one is with 3.
  • Ah, thanks.
    Can you edit line 394:
    --self:logging(3,"Response data: " ..response.data)
    delete the two -- in front of that line of code, save the code and show the output in the debug logging?
    I'm sorry, I'm a newbie.
    Do you mean that I have to do the following steps?
    - Inactivate the Iungo-monitor quickapp
    - change the fqa-file in a text editor
    - Upload the modified fqa-file
    Sorry, I see a possibility to change it in the home center....
    Edited by pollewop
  • Indeed, you can edit the main device. In the tab “Edit & Preview” there is an edit button.
    Then you can scroll to line 394.
    That line should look like: --self:logging(3,"Response data: " ..response.data)
    Delete the two -- in front of it and push the save button on the bottom right.  😃
    I changed line 394.
    Probably there is an interaction with the Hue-Main Quickapp
    I see also the following message:
    [22.04.2023] [21:12:39] [DEBUG] [QA_HUE_MAIN_293]: [L] GetSystemEvents - event - DeviceModifiedEvent QAID: 420
  • No, the debug logging shows all logging for all quickapps. It is all in one place, no problem.
    What does the Iungo debug logging now says?
    Still the same.
    The debuglevel is still 3. I thought that the HueMain could interact because of 'QAID=420' and the Iungo Monitor has ID 420 in my system.
  • Are you sure you saved the changes? Because it doesn’t show yet in the debug logging.
    you mean omitting the '--'?
    Yes I did.
  • That look ok 👍
    Just checking, are you sure the IP address 192.168.68.110 is the right one?
  • The Iungo doesn’t give an answer (operation cancelled). Maybe it is the object ID (oid":"538d72d9"), but I cannot check it, I don’t have an Iungo.
    I hope you can do some research or other Iungo users on this forum can help you out.
    My problem is solved. The wifi-network of the HC3 was not the same as the one connected to the Iungo.
