QuickApp - HomeAssistant
rangee
If this QuickApp helps you, you can give me a cup of coffee
Paypal :
BuyMeA Coffee :
Download QuickApp at MarketPlace :
Download QuickApp here:
/monthly_2021_01/HomeAssistant.png.668fe3a6899e2b9006a76efe9f603898.png" />
QuickApp for HomeAssistant.
It is based on WebSocket protocol.
If you don't know about HomeAssistant then refer here ->
QuickApp Information
Current Version : 0.8
Last Updated : 2021-06-18
Author :
Q&A, Request :
Supported domains : {"cover","light","switch","sensor","binary_sensor","device_tracker","person"}
Excluded entity id : {"linkquality","update_state","action","click","battery","voltage","voltage","voltage","motion_sensitivity","update_available","occupancy_timeout","pressure"}
Install Manual
  1. Install the QuickApp(howto:
  2. Define Variables.
    1. Go to > devices
    2. Open installed QuickApp
    3. Choose Variables tab
    4. Edit the variables.
      1. HA_IP(ex: 192.168.1.1)
      2. HA_TOKEN(ex: easloduiyASKLhjekljha~~~~~~~~~~~~~)
      3. If you can not save HA_TOKEN then open "main.lua" and input tokens.
    5. Save
  3. Install HA entites.
    1. Open side panel of QuickApp or Choose Edit&Preview tab
    2. Just click the button to install child devices.
    3. Done.
Option Variables
  1. Set icon of child devices.
    1. Go to > devices
    4. Edit the "icon" variables.
      1. Type child device id and icon number pairs.
      2. child_id:icon_no,child_id:icon_no,... (ex: 100:1001,101:1002,102:1010)
      3. It is splited by comma , and paired by colon :
  2. Hide child devices.
    1. Go to > devices
    4. Edit the "hide" variables.
      1. Type child device id.
      2. child_id,child_id,... (ex: 100,101,102)
  3. Show child devices.
    1. Go to > devices
    4. Edit the "show" variables.
  4. Change Room of child devices.
    1. Go to > devices
    3. Choose Varaibels tab
    4. Edit the "room" variables.
      1. Type child device id and room name pairs.
      2. child_id:room_name,child_id:room_name,... (ex: 100:Default,101:LivingRoom,102:Kitchen)
Send Service manually
fibaro.call(id, "call", "service_name", "data with json format")
Change Log:
0.4
> First release
0.5b
> buf fix. light with no brightness entity covert to binarySwitch not colorController.
Edited by rangee
hello thanks for sharing. Could you tell me please where to find TOKEN or how to set one?
    Hi. You can find token at
    HA sidebar-profile- bottom  access token
    Thank you very much, I really appreciate your help. I managed to add a token I created but I struggle on step 3 (install HA entities). Could you give me any hint?
    Edited by max_fok
    It not available now because the QuickApp whick I uploaded at marketplace is still "Status in review".
    If my QuickApp appears at marketplace then download the QuickApp and follow the step.
    oops my bad ?! Thank you!!
    Since it's reviewed and ready for download on the marketplace, shall I have to exclude Fibaro from my Home Assistant setup so to avoid to get the fibaro devices reversed back to Fibaro from Home Assistant?
    ?Lol I hope what I wrote ↑ not to be meaningless. Anyway if I don't exclude Fibaro from Home Assistant will I have my devices doubled?
    Hi.
    If you have fibaro components at HomeAssistant, you will grab all of devices from fibaro.
    So if you add your HA devices to fibaro via HA quickapp, added device will appear at HA. It will be duplicated.
    To avoid this, there are options at fibaro components.
    Option name is "plugins" and this is set default as false.
    If you want to plugin option true... than you should edit fibaro components that exclude HA quickapp's child device.
    If many people need it, I can do it.
    I can't find this QA on Fibaro Marketplace, is it really released there?
    Not released yet.
    It is still status in review. That means fibaro is still check it. IDK when review finish.
    1 hour ago, rangee said:
    Not released yet.
    Ah, ok. Thank's! I looked at Max_Fok's post above who wrote: "Since it's reviewed and ready for download on the marketplace", and I thought it really was released.
    Looking forward to your work to come up on the Marketplace! :)
  • As they dont review the QuickApp which I uploaded at marketplace, I will upload QA here soon.
    @rangee Just create a new topic an upload the QuickApp there.
    (The download section also needs a Fibaro review, which can take a long time for initial uploads and changes)
    Edited by SmartHomeEddy
    • Please login or register to see this link.
  • Release HomeAssistant(v0.4) QuickApp 2021-02-20
    Great!!! Thank you very much!!! Little help I need so to set icons on the child devices, where can I find the appropriate icon number?
    Edited by max_fok
  • 25 minutes ago, fok said:
    Hello, is it possible to run under HC2?
    Unfortunately, No.
  • 2021-02-24
    Bug Fix.
    HomeAssistant(v0.5b)
    Hello, I would like to ask if there is any way among other devices that are integrated from Home Assistant to Fibaro to integrate Mi Robot Vacuum.
    Thanks in advance and thank you for the great job you have done here!
