QuickApp - Zigbee2MQTT
rangee
If this QuickApp helps you, you can give me a cup of coffee
Paypal :
BuyMeA Coffee :
Download QuickApp at MarketPlace :
Download QuickApp here:
/monthly_2021_01/zigbee2mqtt.png.fce0b98d7de5104ea8b56a515e784b01.png" />
QuickApp for Zigbee2MQTT.
It is based on MQTT protocol.
If you don't know about Zigbee2MQTT then refer here ->
QuickApp Information
Current Version : 0.81
Last Updated : 2021-08-28
Author :
Supported devices :
v0.80 -> 182 brand, 1172 devices
v0.81 -> 221 brand, 1544 devices
(You can see list at "support.lua" in device editor or
Q&A, Request :
Install Manual
  1. Install the QuickApp(howto:
  2. Define Variables.
    1. Go to > devices
    2. Open installed QuickApp
    3. Choose Variables tab
    4. Edit the variables.
      1. MQTT_IP (ex: 192.168.1.1)
      2. MQTT_ID (ex: mqtt_admin)
      3. MQTT_PW (ex: mqtt_password)
    5. Save
  3. Install Zigbee devices.
    1. Open side panel of QuickApp or Choose Edit&Preview tab
    2. Just click the button to install child devices.
    3. Done.
Option Variables
  1. Set icon of child devices.
    1. Go to > devices
    4. Edit the "icon" variables.
      1. Type child device id and icon number pairs.
      2. child_id:icon_no,child_id:icon_no,... (ex: 100:1001,101:1002,102:1010)
      3. It is splited by comma , and paired by colon :
  2. Hide child devices.
    1. Go to > devices
    4. Edit the "hide" variables.
      1. Type child device id.
      2. child_id,child_id,... (ex: 100,101,102)
  3. Show child devices.
    1. Go to > devices
    4. Edit the "show" variables.
  4. Change Room of child devices.
    1. Go to > devices
    3. Choose Varaibels tab
    4. Edit the "room" variables.
      1. Type child device id and room name pairs.
      2. child_id:room_name,child_id:room_name,... (ex: 100:Default,101:LivingRoom,102:Kitchen)
Set Remote Controller
If you have switch or button zigbee devices(payload with action or click),
you need to define REMOTE table at main.lua
  1. Go to > devices
  3. Choose Edit&Preview
  4. Click Edit
  5. Find "main" and click
  6. Find below then edit and save
** Read manaul carefully **
** You can use Scene instead of REMOTE table.
** Here's sample for button
REMOTE = {
--==--==--==--==--==--==--==--==--== START
    ["btn_p"] = {
        ["single"]      = {id=DT.wallpad_elevator, action="toggle"},
        ["double"]      = {id=DT.light_l_3, action="toggle"},
        ["triple"]      = {id=DT.light_k_2, action="toggle"},
        ["quadruple"]   = {},
--==--==--==--==--==--==--==--==--== END
Change Log:
0.73
> First release
0.80
> Fix bug of cover entity.
0.81
> Fix bug and update supported devices.
Edited by rangee
update
  • Like 3
Korean developer Best of the best
TEST ing
52 minutes ago, max_fok said:
Does it use the hc3 zigbee element
No, this does not use the HC3 Zigbee chip.
it needs another zigbee controller?
A bit more than that. The topic starter already mentioned this in the first post:
"It is based on MQTT protocol.
But to clarify that a bit... You need...
Another controller + computer + setup software, details are here:
It is possible to run that software (Zigbee2MQTT) on bare-metal Linux eg Raspberry Pi, but you can also run Zigbee2MQTT in a Docker container, as the Home Assistant Zigbee2MQTT add-on or even on Windows.
HC3 comes with a MQTT client, and that is what is used here to get date from/to Zigbee2MQTT. If you want the details, see
You do need at least one MQTT server in your network. A popular open source solution is
Thanks both rangee and petergebruers! I struggle using home assistant. I installed it yesterday successfully on a raspberry pi but haven't figured out how to exclude switches from Homekit. The result I got two or three icons for just a light. So I got back to homebridge. Both home assistant and Homebridge support zigbee2mqtt as I ve checked. But I d be interested to integrate home assistant to fibaro someday. I ll try to get tomorrow a cheap Zigbee adapter CC2531 and to figure out how it works so to get a few Xiaomi sensors I have from an old setup. Thank you very much!!
  • 13 hours ago, max_fok said:
    it surely takes much to be reviewed, can't wait to try it.
    Make Fibaro work :(
  • As they dont review the QuickApp which I uploaded at marketplace, I will upload QA here soon.
    I know the feeling
    if you don't post the quick app here, please let us know! Cant wait! Thank you very much for your effort!!!
    As also for the Zigbee2mqtt quick app :)
  • Release Zigbee2MQTT(v0.73) QuickApp 2021-02-20
    hello, just yesterday I set up a Mi wireless switch WXKG01LM on home assistant so to control a group of lights. Via automations I set actions for each one of its functionalities, such as single click, double click and hold. However I integrated that device too via Zigbee2Mqtt quick app on Fibaro HC3 scenes, there is no option of state. Can I do anything to make it work under Hc3 too?
    Hello. There are examples how to do that. Look at post with images.  You should setting REMOTE like this. This is just sample so you should do with your case.
    id should be number.
    REMOTE = {
        ["btn_p"] = {
            ["quadruple"]   = {},
    REMOTE = {
        ["btn_p"] = {
            ["quadruple"]   = {},
    Sorry I didn't get that. Do you mean in the quick app Lua file?
    Yes. In the quickapp  lua files.
    Read carefully, you could find the other way using remote at scene instead of quickapp lua files.
    I see thanks again, though at scenes, choosing the device it shows me only the battery level.
    Oh. Not block scean. Its lua scene. We can't do that cuz child device don't support.
    If you want to use remote at scene, you should do with lua scene.
    OK got it thanks one last question please? In Lua scene do I use the names of the devices as shown in Fibaro or the entity name in home assistant? Sorry for such many questions. Thank you really much for you help!
    DECLARATIONS
      conditions = { {
          isTrigger = true,
          operator = "==",
          property = "zigbee2mqtt",
          type = "custom-event"
      operator = "all"
    ACTIONS
    local r,c = api.get("/customEvents/zigbee2mqtt")
    if c == 200 then
        local value = r.userDescription
        local id, action = string.match(value, "(%d+):(.+)")
        print(id, action)
    id is remote controller's id and action is action of remote controller's like single_press
    If R-C device id is 100 and action is single_press -> turn on id 101
    if id == 100 and action == "single_press" then  fibaro.call(101, "turnOn") end
