adamdeluxe 0
Dear community,
I went through a lots of posts here but unfortunately I cannot find a solution for my issue.
I am operating 9 Fibaro Roller Shutter for my window blindings since 2016 in combination with a Home Center 2.
From the very beginning I had issues to calibrate the roller shutters.
If I do it from the closed position:
The shutters can be used to drive the blinding up or down. They work.
Also scenes can be set-up and the shutters are included and to what they should do, drive down and up.
Because of the lack of calibration the blinding level (0-100%) cannot be set/ used. Nigher over the slider, nor with a scene.
Now it becomes funny. Today - don´t ask me why - I created a scene to close the shutter of my office room 50% and (surprise) it has worked.
Also the calibration is working, but only with the shutter in my office room.
I tried to be smart and checked all settings/ parameters or the working shutter - I have not found any special set-ups - and checked the parameters of the "bad shutters".
I have still the same problem: I cannot calibrate the shutter and so I cannot set-up levels, nigher over the slider, nor over the scene. (just in the office room).
If you need any further information, please let me know.
Best regards
PS: I tried to change the Q1- and Q2-wires... same calibration issue and on-top wrong allocation of the commands up and down.
PPS: I also tried to play with parameter 18, I went down to 1 and up to 150... not successful
5 answers to this question
