Homeseer with FGBS-222
Accelerator Engineer
I'm using A hometroller SEL 3.16.0 running HS3 3.0.0.531
I'm working with a Fibaro FGBS-222 v5.1 smart implant (Z-wave version).
I initially tried including as a secure node.
When I did I got an error message about it not installing correctly and that some features would not work. I suspect that this is because they include a DSK number that you are supposed to use during inclusion that I was never prompted to enter.
So I included it as non secure without errors.
It created a total of 23 devices most of which I don't understand what they are for.
However, the analog input works and the relay outputs work.
The only thing that seems to be missing is the device(s) for the DHT22 temperature / humidity sensor.
In the log file I see entries like this:
(2) Sensor Multilevel Report for type Air_Temperature received, but the corresponding device Node ID cannot be found.(2) Node/Instance=54/-1
I have already tried going to the root node, opening the Z-wave tab, and clicking on the Rescan button.
This added some of the devices listed above but did not add any for temperature and humidity.
(I think there may also be a built in temperature sensor in the smart implant)
Is there any way to get the missing child devices?
4 answers to this question
I have the same problem and I've tried the same steps that you did. The only difference is that I'm running HS4 on a Zee. I created a ticket with HS, suggest you do the same. The squeaky wheel gets the oil...
  • I already did create a ticket with HS.
    Their response was:
    It isn't possible to manually add Z-Wave features, though you can click on the device's root feature, which is the top one listed for it in List view of the Devices page, it will have a black and white gear icon on the left. After clicking the name, go to the Z-Wave tab and click Manage. From here, use the Rescan button and check your Devices page again once it is complete.
    That's the same i said
    there is also a hint while adding a device
    if it reads example 7 out of 10 child devices created, you know you mis a couple of devices, a rescan often solves this
  • When I do a rescan, the log file says:
    18 out of 18 Child devices of node 54 were created successfully.
    When I count them there actually are 22 child devices plus the root device
    Still no devices for the DHT22.
