fastvd 7
Hi to all.
I have HC3 for about 5 months, everything is OK, now I bought another HC3 and when I first started I installed a static IP and accidentally specified the wrong address: 192.168.0.255 which in fact can not be used on the network ... but HC3 accepted it and now I do not have access to the controller (request to developers to eliminate this glitch) ... according to the recovery instruction it all comes down to: when I'm in recovery mode - then you need to go to the web interface ... but my IP is not correct and I do not I can go to the web ... read the instructions for HC2, there was a static IP 192.168.81.1 in recovery mode ... in HC3 it's definitely not him ... and on DHCP I can not get HC3 to get the address ... what should I do?
7 answers to this question
