QA Virtual sensors AIO (All in One)
petrkl12
QA Virtual Sensors AIO (All in One)
Why to use AIO virtual sensors:
  • Possibility to create any hierarchical structure of sensors (real and virtual) - eg motion sensors for room, floor, object,…
  • Switch the virtual sensor on/off
  • Simulate the setting of values for temperature, light, wind, humidity, etc.
  • Generate motion in a room where no one is and test the functionality of your home automation
  • Clone the sensor to another room
  • Correct the values
  • Mathematical conversions eg. km/h to m/s
  • Select how the final value for more sensors will be calculated (Average, Sum, Min, Max, Newest, Oldest)
  • Detail view with all values and time of updates
You can come with your own ideas how to use it :)
INSTALLATION AND DETAIL INFORMATION:
1.Motion sensor - I use it as a main motion detector in all rooms/floors/buildings - it can concentrate all the devices that can show me that someone is there. Any motion detector (in Variables - Devices), opening or closing doors / windows (in DevicesDW) and then all remote controls / switches that generate Central Scenes (these are in DevicesCS)
This is how I have it in all rooms and then I put the individual virtual detectors in the Floor / Ground Floor / Outdoors and then on the Floor and Ground Floor I make a movement in the House - basically any combination :). Virtual and physical devices can be combined.
All other things (scenes/QAs) I have connected to these central sensors.
Other use cases:
- keep track of which devices in detail and when they last generated motion
- generate movement by pressing a button (suitable for testing, for example - you don't want to go into the room, so you just create the movement virtually)
- turn on / off the virtual sensor (you have a sensor connected, for example, in the alarm zone, but something is wrong, so you simply turn it off remotely)
Other parameters:
Delay - how long after the sensor the sensor returns to its original state (default 30s)
MotionSensOn - whether the sensor should be in the On state after restart (values are Yes / No, default Yes)
2. Sensors: Power, Light, Temperature etc.
Why to use:
- I want to have an average value from more devices and then use it as the main indicator for a given room
- I want to test something - I can set any value, both manually and from another QA or scene
- I can create a sensor with an empty list of devices and send values from another scene or QA (or even manually)
- I can turn the sensor off / on (if the sensor is off, I can still set the values manually / programmatically). When enabled, the manually set value will be overwritten when the first new value arrives from the defined devices. If the sensor is switched off, the set value remains there.
- I can define how the final value will be calculated - can be used: Average, Sum, Min, Max, Newest, Oldest (TableOper item)
- use for rounding values,
- for correction of measured values
- can be used for any unit conversions - for the resulting value calculated according to TableOper, a mathematical expression (ValueOper item) will be used, eg Value + 2 or (100 * Value + 2) / 1000 (if you do not specify Value, the result will be a given constant or calculated constant eg 10 or 3 + 12 + 20)
- can also be used for cloning to another room - for example, you have a hygrometer in the living room and you want to add it to the kitchen
- you will certainly find other uses :)
Settings:
all sensors have more or less the same settings - they only have a different set of default parameters
- Devices: list of devices to be connected to the virtual sensor (comma separator), default is 0 (no device is defined)
- TableOper - how the values coming from Devices are to be processed - can be used: Average, Sum, Min, Max, Newest, Oldest
- ValueOper - how the resulting value from TableOper should be further mathematically processed - the default is Value, ie. unchanged - basic mathematical expressions including parentheses can be used
- ValueRound - how to round the resulting value - how many decimal places
- Unit - what is the sensor unit
- SensorOn - whether the sensor should be switched on after restart (values Yes / No)
3. Power consumption for Light / Device
I use to set the power for devices that do not measure power themselves. It can be used both for devices that have an On / Off status and for devices that are regulated and have values of 0-100
Settings:
Device - only one device can be entered
MinPower - consumption in the off state
MaxPower - consumption in the on state at 100%
ValueOper - how to calculate the final consumption - for the off state is Value 0, for the on state is Value 100, for controllable devices the value will be 0-100 or 0-99 (depending on the type)
Unit - default - W
SensorOn - whether the sensor should be switched on after restart - Yes / No (default Yes)
Technically, all devices are Child, including the user interface. The advantage is that they consume less memory than stand-alone QA devices. It is possible to have more main QAs in the system, for example one for motion detection, other for consumption measurement, etc. So far I only have one with more than 40 child devices :)
QA works on the principle of capturing events (it is very fast) and does not query all defined devices on a regular basis.
Each time the setting is changed, the name of any device is changed, the room is changed, the main QA and the child device are restarted
Files:
Edited by petrkl12
  • Like 4
6 answers to this question
Some hysteresis or thresholds or average over a time window? Makes sense for stuff that fluctuates a lot like ex. power.
  • @jgab
    I was thinking about time weight average ie. for power consumption : ((time period 1 * value1 + time period 2 *value 2+ ... / sum(time period))
    How it should work with hysteresis or thresholds? Any example could help :)
  • if somebody wants to test this QA please let me know via pm
    22 hours ago, petrkl12 said:
    I want to test
    Edited by minsad79
  • updated first post incl QA
