Upgrading from HC2 to HC3. Is the consumption energy panel fixed?
Alfamonk
Hello everyone!
I was "praying" to the gods of Fibaro for years to increase the HC2 logs for HC2 consumption panel... but that never happened. Therefore, my charts/logs can't even handle one single month of data. I've reduced the time my devices logs the energy consumption to max, but I can't go that low with such expensive products...
So, after so much waiting, I have decided to move away from HC2. To HC3 or something else.
Now, the big question is: have Fibaro increased the energy consumption data logs for HC3, or are they still the same as HC2... and in that case I would just give up on Fibaro HC completely?
Thanks in advance!
1 answer to this question
If it is that important to you, see here for a great solution, store the data in InfluxDB and make graphs with Grafana.
Edited by SmartHomeEddy
