Remote Gateway connections lost
rvegting
After this update the connection between my HC2 and HCL was lost. I have tried to reconnect the HCL, but the HC2 can't find any gateways...
How do I resolve this?
- type the HCL IP manually, instead of searching for the HCL
- ensure you have not changed the user/password (or that you are not locked - simply reboot both and try again then)
