QuickApp - SolarEdge Monitor
SmartHomeEddy
This QuickApp monitors your SolarEdge managed Solar Panels. The QuickApp has (child) devices for current Power, solar Power, lastday, lastmonth, lastyear and lifetime energy. The peak power and currency setting are retrieved from the inverter. The readings for lastmonth, lastyear and lifetime energy are automatically set to the right Wh unit (Wh, kWh, MWh or GWh).
Changes version 1.2 (26th August 2021)
  • Added values update main device to power interface to show usage in Power consumption chart
  • Solved a bug in the lifeTimeData.revenue existence check
Changes version 1.1 (21th August 2021)
  • Changed back currentPower measurement to Watt and lastDayData, lastMonthData to kWh (not to mess up statistics in Energy panel or InfluxDB/Grafana installations)
  • Changed Child device currentPower to Main device with type com.fibaro.powerSensor (Watt). So the Main device will show the current power production, no Child device necessary.
  • Changed Child device lastDayData to type com.fibaro.energyMeter (kWh). These values will be shown in the new energy panel.
  • Added automaticaly change rateType interface of Child device lastDayData to "production"
  • Added extra check on apiKey and siteID, if not OK then change to simulation mode
  • SolarEdge Monitor settings currency and PeakPower also available in simulation mode
  • Changed the lastUpdateTime to format dd-mm-yyyy hh:mm
Changes version 1.0 (30th July 2021)
  • Total m² solar panels added to log text and label text
  • Check for API existance of lifeTimeData_revenue (not available in older firmware)
  • Automatic conversion added for lastmonthData, lastYearData and lifetimeData production to Wh, kWh, MWh or GWh
  • Automatic conversion added for currentPower to Watt, Kilowatt, Megawatt or Gigawatt (yes, Megawatt and Gigawatt is optimistic)
  • Get the Peakpower and Currency settings from Inverter
  • Peakpower added to label text and child device log text
Changes version 0.3 (12th April 2021)
  • Added last update date / time
  • Cleaned up the code
Changes version 0.2 (12th April 2021)
  • Disabled revenue value (not for lifeTimeData)
Changes version 0.1 (11th April 2021)
  • First (test) version
/monthly_2021_04/solaredge.png.accf8121c3f5c7a882321cfde3e3ea38.png" />
QuickApp variables (mandatory, they will be automatically added with the default values):
  • siteID = Site ID of your SolarEdge installation (see your Inverter Site Details)
  • apiKey = API key of your SolarEdge Inverter (contact your installer if you don't have one)
  • solarM2 = The amount of m2 Solar Panels (use . for decimals) for calculating Solar Power m2 (default = 0)
  • interval = The daily API limitiation is 300 requests. The default request interval is 360 seconds (6 minutes).
  • debugLevel = Number (1=some, 2=few, 3=all, 4=simulation mode) (default = 1)
  • icon = User defined icon number (add the icon via an other device and lookup the number) (default = 0)
Tested with:
SolarEdge firmware version 4.12.35 and 4.13.40
Download the QuickApp here (download the file and un-zip):
How to install:
  1. Open the Configuration Interface
  2. Go to Settings > Devices
  3. Click  +
  4. Choose Other Device
  5. Choose Upload File
  6. Choose file from your computer with .fqa
Edited by SmartHomeEddy
  • Like 3
  • Because I not YET have the SolarEdge Monitor, I build a first version of a QuickApp and am looking for testers of this version.
    @SmartHomeEddy i have the solaredge (Fronius) and using it with HC3 for quite some time through a QA.  Best is if you also have the smartmeter, then there are no limitations in interrogating the API.  I'm not at home now but will get back in 2-3 days and i can test your QA if you want or share mine.
    Send it @SmartHomeEddy, I'll test it for you :-D
    This is my QA as of now
    Edited by Bodyart
    Added the benefits :-D
    @Bodyart& Eddy
    Guys you make me jealous!
    I will investigate if my both inverters can be connect WIFI to join with your QA the info in my HC3
    Thanks!
    Do you also have integration with high energy consumers?
    //sjakie
    I have Delta and Growatt
    Just requested Deltazon.nl to offer WIFI connection.
    Need some buss, stick, print cable.
    I am curious
    //Sjakie
    I am investigating what else I need to purchase. There is for example a Modbus extension.
    /monthly_2021_04/image.png.5f38831d47ab922bd6858f17a56a10a0.png" />
    But I already have my smart energy meter from the energy company with the P1 Monitor and the QuickApp. There I also can monitor the production on all three phases.
    The QuickApp will start in debugLevel = 4, simulation mode, it will use some test data. You can fill in the right siteID and apiKey in the QuickApp variabels and set de debugLevel to 3. Then the QuickApp will request the data from the SolarEdge portal.
    You can set the interval to 360.
    In the API documentation there was also revenue for day, month and year, but aparently there is only revenue for livetime. So I changed the quickapp to version 0.2.
    Some of us read your remarks in the code :-D Every tester should do!
    I uploaded version 0.3 in the first post. @Bodyart thanks for testing.
    On 4/11/2021 at 6:54 PM, SmartHomeEddy said:
    valuta = Name of the valuta your saving with solar energy (default = euro)
    For version 0.4 the valuta can be retrieved from API :-D
    Great app. I have changed the overall and yearly to MWh instead of kWh because of the big numbers.
    Also increased the API polling interval to 600 because my mobile phone also has a SolarEdge app that requests the site details.
    Thanks for making this, it's working great!
    since last week I've a solaredge inverter. Installed AQ in debug mode everything seems to work, great!
    My icons won't update, seems to stay in demo mode numbers.
    Any ideas ?
    Roelof
    Hi Roelof,
    if you set debugLevel to 3 (or 2 or 1) and enter the sideID and apiKey, it should work. If not, you should see some debug messages with more info.
