Timeout after update to 1.11.0
Pane78
Hi everybody,
after updating to Home Center 1.11.0 I'm experiencing timeout connection error several times a day.
After two weeks I decided to open this post, do anybody is experiencing the same behaviour?
Do you know if there is the possibility to downgrade to previous release?
Hello Pane78, are you sure this is not the case of your internet connection or ISP? Did you maybe have the chance to check what is the status of your Home Center in FIBARO ID via id.cloud.fibaro.com?  Is HC available via id.cloud.fibaro.com when you encounter these timeout connection errors?
