RGBW2 & HC3
Sasa
i'm having some issues for basic configuration:
SWITCH BUTTON -> RGBW2 -> RGBW Led Strip
clicking the button nothing appens ...
so i configured a scene where 1xclick power on the controller, set white color and 70% brightness and a second scene where 2xclick power off the controller
now it works, 1xclick on and 2xclick off .... but there is a way to obtain a simpler conf avoiding the scene ?
what i'm looking for is: 1st click button -> power on ; 2nd click button -> power off
thanks
10 answers to this question
35 minutes ago, Sasa said:
SWITCH BUTTON
Is it physically wired to RGBW2 module?
1 minute ago, Sasa said:
yes, as raccomended by fibaro manual scheme
OK, then you should be able to get it turned ON/OFF without scene.
If RGBW2 module is set as RGB or RGBW role and inputs are in RGBW mode (param 150), then set parameter 150 to HSB and White and IN 3 should turn ON and OFF your RGBW module and scene is not needed.
  • so i need to change 150 to 1 and disable all scenes ? just that ?
    Yes
  • ok, i'll try later today and get back to you :) thanks
  • 10 hours ago, jakub.jezek said:
    Yes
    Jakub, unfortunately putting rgbw2 into "HSB & White Mode" nothing appens, clicking the button do nothing. Any other ideas ?
    Button on IN3, not IN1.
    15 hours ago, jakub.jezek said:
    ... then set parameter 150 to HSB and White and IN 3 should turn ON and OFF your RGBW module and scene is not needed.
    @Sasa, have you revired Button to Input 3?
    Do you have turned on počal protection oř not? If yes, turn it off.
    Is Buttosn Input GND or +12 Volt? Must ne GND.
    I have a scenario with monostable switch (GIRA) + RGBW controller + RGBW led strip. "W" channel connected to GIRA switch
    - 1 click on (white  on)
    - 2nd click (white off)
    Sorry for polish version (protected mode is "ON"
    Other colours/scenes available only through:
    - HC3
    - mobile app
    - or additional equipmet ie. Aeotec wallmote
