HC3 LIte and missing Fibaro App Problem
MaciekJ
Hi, Before I start with adult HC3 I bought HC3 Lite to do some testing. I bought also few devices (Fibaro only) and replaced part of my outdated Eaton Xcomfort. The problem which I noted very quickly is that integration with Philips Hue went OK only in Web App. In Android App I can turn on Hue device as a on/off switch but tying to enter more settings app informs me only which version od HC3 soft should I have. Of course my version is higher than mentioned in the app after recent update.
Can someone help me? It is a problem of HC3 Lite?
3 answers to this question
Already reported, this will be resolved on the apps side.
@m.roszakthe problem of missing icons ? will that be solved shortly also?
App 1.11.0
HC3  5.070.42
IPhone 14.4.2
With all those ? its dificult to navigate.
//Sjakie
There is a different topic about it (icons) - and I think that there is no issue there - just need to connect locally to HC and then icons will be synchronized.
