Login locally error
MikeALL
I have HC3L, the same wifi, correct credentials. Mobile android. Yubii app.
BUT still the same error - NO connection to hc3L
But HC3L normally works, I can ping it from mobile, connect via ID and firefox.
Any Help?
  • the solution is NOT check https.. if you have https only you will not connect locally.
    Maybe it helps to some frustrated men.. :-)
    Mike
