Solar inverter - SAJ R5-10K-T2 - data implementation
dareszek
Hello everyone,
I have an R5-10K-T2 SAJ inverter, unfortunately I did not find an open API in it. The only thing I can see (because it displays data on an internal web server via Wi-Fi) is its status, which in the path
displays a string of numbers that can be identified by what mean ... Unfortunately, I can't cope with the implementation to HC2 to expose the data. Can anyone tell me how to get php data? after entering the abovementioned path http: // I get the sequence: 3, 14352, 559, 99, 29, 6380,189,0,0,65535,65535,65535,65535,65535,65535,65535,65535,65535,65535 , 65535, 65535, 65535, 65535, 1157, 5001, 2413, 182, 2419, 186, 2438, 186, 6684, 341, 1126, 2 . Maybe some of the users have such an inverter and somehow coped with it? Unfortunately, I'm not a programmer and hence the problem ...
I am asking for help and best regards
3 answers to this question
Any luck with your intergration of SAJ to the Fibaro system?
I'm also looking for a way to import the SAJ inverter data to the Fibaro Energy Panel (HC3)
Hope to hear from you
Sería algo así, por ejemplo para coger el valor 24 de la cadena:
