Separate sensing from controlling
Bert
Hello everyone,
I'm considering to use a Fibaro FSG-213 in combination with a wired PIR sensor and Home Assistant. The PIR sensor would be wired as switch and the Home Assistant would be configured to control the light. See
for another description and a wire diagram. The special aspect is that the switch should not switch the light on when motion is detected but leave decision to Home Assistant.
Is that a possibility? If so, how should I configure the switch?
Thanks in advance!
Bert
Edited by Bert
Looking at the manual, I think this should be possible if you connect the pir switch output to S2. Change parameter 29 to 1 to allow a scene to be triggered. No need to connect anything to S1.
