Can I update this BETA firmware to HC3 system with gateway connection?
Poom
I'm running two HC3 as master and slave using gateway connection (total around 400 devices).  Can I update this BETA firmware to both master and slave unit as earlier firmware update?  I plan to stay with Zwave 2.0 for now, no plan to move to Zwave 3.0 at this moment.
Yes, that works fine. I have 3 controller, that works ok.
My problem is that when I did the update, it became unstable and reboot a bit more than once per hour. That was giving me some issues and I switched back to the previous version.
  • Thank you for your feedback.  I'll skip this version then.
    • 4 weeks later...
  • Hi @Pete123 or other users who use gateway connections,
    Have you tried the new firmware 5.072BETA?  Is it stable to install and to try?
    Thank you.
