LUA Code On Quick App HC2
macrob86
Hi
I have to understand the Quick app HC2 code to make the same app to HC3.
This Quick App control Multiroom AMCP MR4.50-XT - 4 Zones with Itach RS232 Serial Interface.
I do not understand where in the LUA Code call function like above:
local ID_VD = fibaro:getSelfId()
fibaro:call(ID_VD, "pressButton", "6")
fibaro:sleep(600)
fibaro:call(ID_VD, "pressButton", "16")
fibaro:sleep(600)
fibaro:call(ID_VD, "pressButton", "26")
fibaro:sleep(600)
fibaro:call(ID_VD, "pressButton", "36")
fibaro:sleep(300)
Where I need to looking for some information about this code?
The best way of doing this in a HC3 Quick App is using the following Timeout Command
fibaro.setTimeout(3000, function() self:SetCool() end)
This combines your two commands together, it delays the action by 3000 (3 Seconds) and then runs the SetCool QuickApp function
An Example
function QuickApp:setThermostatMode
local Mode = Cool
if Mode = cool then
You would just need to change out the SetCool Command function with the Specific Functions you have set up, and you can call multiple of these Timeout functions in the same command
fibaro.setTimeout(1000, function() self:TurnOnl() end)
fibaro.setTimeout(5000, function() self:SetFan() end)
  • Do you know Where can I find the reference of "pressbutton"
    Is there anywhere to consult?
    I see the code use another way to switch on the device,
    I think it is a direct access.
    Look in the Quickapp manual for supports control
     on how to handle button events.
    I use for example this code for a "refresh" button
    (If necessary with a setTimeout() inside)
