Which LUA command to read values imported with api.get?
Alex V
I have used the api.get("/profiles/5") command to put data into a variable.
Now I can read out the first level, for example name, but not deeper. I want to be able to reach all the values of the climate zones.
Can someone explain to me how I can access these values and write them back in an appropriate way?
example code:
local MyVar1 = api.get("/profiles/5")
print (MyVar1.name)
The value which I read in MyVar1 see attachment (viewed with swagger)
Thank you in advance for your reactions
Hi @Alex V ,
Here is sample code:
Hope this helps
Hi @Sankotronic,
You're a very fast coder, but in this case you forgot to add 'do' in your for - next loop :-D
the code shoul'd read:
for z=1,#MyVar1.climateZones do
  print("Climate zone no "..d.." ID: "..MyVar1.climateZones[z].id)
  print("Mode: "..MyVar1.climateZones[z].mode)
  if MyVar1.climateZones[z].mode=="Manual" then
     print("Manual mode: "..MyVar1.climateZones[z].properties.handMode)
     print("Manual setpoint: "..MyVar1.climateZones[z].properties.handSetPointHeating)
  • Thanks 2
Today I have very little to do... :-)
    Thank you guys for your response. I got an error on ..d.. have changed this to ..z.. Now it gives the value of the loop. Was that also your intention?
    Hi @Alex V ,
    that was typo. d should be z. @jgab solution is better on the coding side, less typing. My solution is better to understand how to get deeper into the table tree to get desired data. :-) In practice I use mostly ipairs or pairs to loop through table data.
