QA stop(script problem) but not print error problem [SOLVED]
jwetzel
I have a weird behavior with my HC3. When I make an error in my code, the program stops but there is no error showing in the console.
After a few seconds, it automatically restarts the program.
It only shows me parentheses errors, "end" missing or = missing or handlejson error.
But nothing else.
It also often happens that the HC3 is no longer accessible for several minutes following an error without it being a loop problem.
And still without displaying an error in the console.
Is it normal ?
Thanks for your help.
Edited by jwetzel
solved
15 answers to this question
You can also add the fibaroExtra.lua file to your QA. It will protect setTimeout/setInterval and net.HTTPClient and log errors if callbacks crashes. Also gives better error for json.encode/json.decode...
  • 13 minutes ago, jgab said:
    How and from where do you call it?
    You get that error if you call :updateView on the class object (QuickApp) directly instead of the instance object (self)
    Ex.
    causes that error.
    works
    fibaroExtra don't patch or redefine :updateView
    Button run this function (main)
    Swisscom:updateInfo() save datas in the variable and run this function (main)
    Thats not correct ?
    But nothing else.
    Is it normal ?
    If your code dies (has a bug) in a setTimeout/setInterval you don't get any error. In that case you need to wrap the function in a pcall. You can also have this issue with net.HTTPClient() callbacks to success/error.
    If your QA crash it automatically restarts after ~60s.
    • Like 3
    Oh nice ! YOU SAVE MY LIFE
    Haha
    You are a boss, thanks !
    Jan, add to main?
    Or does it come later in an update ER4?
    //Sjakie
    48 minutes ago, Sjakie said:
    Jan, add to main?
    //Sjakie
    pushed ER4 v68 where I have back-patched it from fibaroExtra to Toolbox.
    Jan,
    12 minutes ago, Sjakie said:
    Jan,
    Oh, really bad. I pushed a fix but it's too late for people that already upgraded.
    Go into the QA files and the file "Toolbox" and line 694 and change
    to
    Thanks!!!
    You added more errors in debug?
    Found another 10 pieces with this update.
    //Sjakie
    10 minutes ago, Sjakie said:
    Thanks!!!
    //Sjakie
    Yes ?
  • @jgab, I don't know if this is a problem with the fibaroExtra, but it tells me an error of a function that does not exist in my code.
    /monthly_2021_07/image.png.1ae5e4f97262fbb6ae64c7c4c848b792.png" />
    This error occurs when I use self:updateView("label1", "text", "my txt")
    Thats weird :/
    Thats weird :/
    Ex.
    causes that error.
    works
    Ex.
    causes that error.
    works
    Button refresh call function (in main)
    After get data in others functions, the last function call this function (in main)
    Thats not correct ?
    Somewhere in the call-chain something goes wrong - do you want to share the code with me in a PM and I can take a look at it?
    Swisscom is a class or your homemade table object?
