Fibaro Implant
bluesti
Hi
Is it possible to pair an Implant with a VeraEdge controller? If so, which device type should I select?
Cheers
John
It is possible to pair a Smart Implant to a Vera as a Generic Z-Wave device, however you will need to have a look around the Forums for a fix for it as by default the Vera does not support it correctly.
