Probably a really stupid question... sorry
tvs
After many years using a HC2 I've now moved into a new house and have a HC3.
I was pretty okay at LUA on HC2 but i'm completely lost now on HC3.
My stupid question:
I have a few scenes that set the indoor lights, I also want these scenes to switch the outdoor lights on, only if its night. So I've set a variable isitnight and I thought I could create a block scene which checks this variable, ifitsnight = 1 then switch on the lights. Problem is its just not working, in either block scene or LUA.
Please see attached screen shot and LUA below. Any help would be much appreciated.
thanks
tom
  conditions = { {
      isTrigger = false,
      operator = "==",
      property = "isitnight",
      type = "global-variable",
      value = "1"
  operator = "all"
fibaro.call({[1] = 147, [2] = 162, }, 'setValue'100)
fibaro.call(189'turnOn')
15 answers to this question
  • thanks for the fast reply!
    I dont want it to trigger the lights to switch on though, I want to run this scene from another scene (So that will effectively be the trigger) does that make sense?
    if you run the scene manually it will run?
    so the other scene has a command run thos scene? please show screenshot.
    other thing you can do:
    create new var: outsidelights on and off (or 1 and 0)
    remove the start scene in youre other scene
    add set var outsidelights to on (or 1)
    change the other scene
    the var you had to outsidelights is on (or 1)
    and tick the trigger box, the it must work
  • So basically I have a scene called Cozy which sets various indoor lights. If i run that scene in the day i dont want it to switch the outdoor lights on. But if I run it at night I want them on.
    In the past (HC2) I just made a scene called outsidelight which checked a global variable called isitnight, and if isitnight = 1 then it would switch the outside lights on. It worked really well as i could run the outsidelight scene from a few different scenes
    attached is a screen shot of cozy, and isitnight.
    thanks
    tom
    if cozy is a block scene on it's own, it has no trigger so it will never run
  • cozy is a block scene that i run from the app, ir with google assistant
    so cozy works well, the problem is that the outside lights come on regardless of the time of day, its almost like its not chekcing the variable
    i'm having toubles to see the whole picture
    so cozy is run manually and starts the garden lights scene? that should be set var to 1, because that will trigger that scene
  • Sorry I've not been clear.
    these are the scenes i have:
    • a scene which sets the isitnight variable to 1 when its 60min after sunset.
    • a scene which sets the isitnight variable to 0 at sunrise
    • Cozy which switches a load of indoor lights on, and runs my garden Lights v1 cozy is alweays trigged via the app or google
    • garden Lights v1 which checks the isitnight variable, andf if its 1 then switches the outside lights on.
    The problem i have is that garden Lights v1 doesnt check the variabvle and seems to justr switch the lights on regardless.
    hope thats clearer
    That is correct, run a scen will always run that scene without checking trigger.
    thats's why change it to this
    remove the start scene block, and let the other scene trigger on a variable
  • sorry for being dumb, what do you mean with " remove start scene block":
    you have a start scene block, so the scene will always start. and that is not what you want
    Guest deSmartHomeChef
    Hi tvs,
    I think what you're trying to do doesn't work with manually started block scene. Starting a scene from another scene is a manual scene start. When a block scene is started manually it only runs the actions and does not check the conditions.
    If you need to check conditions with a manual started scene start you need LUA. There the conditions can be checked in the LUA code (action window). Try the LUA scene below for 'Garden Lights v1'. Since you used LUA on HC2 you know how it works.
    Condtions:
    Actions:
    if fibaro.getGlobalVariable("ItisNight") == "1" then
        print('it is night, lights on')
        fibaro.call({[1] = 147, [2] = 162, }, 'setValue', 100)
        fibaro.call(189, 'turnOn')
    else
        print('it is day, so no lights on')
    Hope this helps you to get the Cozy lights on at night ?
  • Thanks to both of you! the LUA above works perfectly and makes sense based on the HC2.
    I just need to get my head around the new split screen LUA coding setup.
    Thanks!
    tom
