[SOLVED] CPU usage index color
SmartHomeEddy
Small cosmetic issue, the index of (in my case) Core 2 has the wrong color. It has the orange color, it should have the blue color. The graphs are green, blue, purple and orange.
(Maybe you could make the four dashboards (light blue) the same color as the graphs, then you don't need the index.)
(Not an issue introduced in this firmware version, also in previous version)
Edited by SmartHomeEddy
YES, I reported that over a year ago, but nothing happened. The problem does not occur in the "Light Theme".
On 8/13/2021 at 2:38 PM, SmartHomeEddy said:
ah, I see. Sounds like a small repair, but it apparently takes a lot of time.
I think that this not a critical issue, we have a lot on our plate and this one is pretty low on priorities.
If this is important for you guys I will push it up in the backlog ;)
  • It is just a cosmetic issue, but is still is a bug. If you have for that long time too much on your plate to also solve minor bugs, something is wrong.
    We are solving minor bugs all the time, there are a lot more of those than most of us realize ;) - this system is huge, always will be some.
    This one is just not solved yet.
    • 1 month later...
    /monthly_2021_09/image.png.6fc6c7de0c6e0590b6b60d9bb37fc866.png" />
    @m.roszak According to jwi the problem didn’t occurred in the light theme?
    • SmartHomeEddy changed the title to [SOLVED] CPU usage index color
