Experience with mounting Walli using Gira hardware? And suggested small improvements.
Intvelt
I've recently replaced a bunch of ancient Duwi Z-Wave switches with Walli ones.  The Walli switches offer a lot of functionality and seem to be of good quality, but I wasn't entirely happy.   I mounted most of the Walli switches in Gira frames, and the result feels... wonky.  The switches end up feeling mushy and their action has a decidedly cheap feel to it.  I haven't been able to put my finger on why the switches operate so poorly with Gira hardware, but it might be due to a poor fit of the Gira rocker into the Walli component.  The switches also don't look all that great with the LED backlight active either.  What are people's experiences with Walli in combination with Gira hardware?
I'm hoping to see some improvements, but below are some ways I already got things to an acceptable level of quality.  BTW, I did mount a few of the Walli switches / scene controllers in the original Walli (round) hardware, and those do look and feel good.
Issues:
- Gira rocker does not stay seated in the Walli switch.  Solved by roughing the rocker's interface surfaces a little with coarse sandpaper
- Walli backlight looks crappy in combination with the Gira switches.  Solved by applying silver spray paint to the insides of the Gira rocker.  The silver paint blocks the light coming through the rocker, but reflects enough for it to shine around the edges.  In a cinch, you can use silver duct-tape.
- Switching action feels mushy and cheap, sometimes you have to push the rocker in rather far to actuate the switch.   Solved by modifying the moving part of the Walli switch, by glueing two plastic shims in the wells under the metal springs.  This makes the switch feel crisp and reliable.
(Happy to post pictures of this if anyone is curious)
Also: the old Duwi modules turn on/off the light instantly when you operate them, which greatly adds to their premium feel.  The Walli switches however take around a second to react.  Is this something that could be improved?
Edited by Intvelt
16 answers to this question
Well, i don't think that i am the right guy for this, i also have my home full with duwi switches and i also wanted to exchange them with walli.
Thanks to the fact that fibaro ignored every question that i had regarding the walli... i decided to keep the duwi modules and didn't buy walli modules.
So my advice is obvious....
that was afaik fixed some time ago, what is your production date?
right, that looks only cool as backlight middle of the night, white looks crappy, blue looks cool, especially if your GIRA is already black
hehe same here
pictures? always ...
the action will be taken after the rocker has been released, plus few ms till relais goes on, yes, that "feels" long.
An firmware option to react on "button down" instead of "button up" would be nice, maybe is there hidden params for that @m.roszak ?
  • Not sure what the production date of these things is, but I bought them very recently.
    I'll post a picture later.
    I still think Walli is a very good option.  Feature wise they are nice compared to the Duwis, which have no status push for instance, and the later versions of the Duwi I got (made by Z-Wave.me) had software issues; they liked to associate with random other devices for instance.  Of all the options out there for Euro style wall boxes and fascia, Walli still seems one of the better options.  Just have to hack them a little...  The most important thing: my wife doesn't hate them :)
    @Intvelt there are 2 versions, the .me version has status push.
    I know robbshop has/had several 3d printed things for walli if you are using the gira55 series
    You can turn off the leds with the parameters.
    did you already contact your reseller for the gira issue?
    It will be nice if fibaro has a product that can be used with gira55 system, that the leds are still useble
    They are usable, it just looks a bit meh.  And spray painting the inside of the Gira rocker makes it look much better; that's a cheap and easy fix you can apply yourself.  That's why I have not contacted my reseller about this (actually got some of the switches from Robbshop).
    As for the crappy tactile sensation when using Gira hardware, below is a picture of what I did to fix that.  The dark grey bits circled in red are small plastic shims glued in place under the two metal springs (one of the springs is removed in the photo).  It's trial and error: mount this part back into the Walli switch and test, and keep filing down the shims until the switch works reliably without sticking.  This makes the switch feel much firmer, with shorter travel and a good positive click action.
    No Walli controller only fits Walli.
    I assume it has something to do with the place of the battery and the way how you fit a gira button
    @pnutp0wer according to the fibaro website:
    FIBARO Walli is compatible* with front plates of other manufacturers: GIRA - System 55**, Legrand - Celiane, Schneider - Odace. If you are attracted to the sockets you already have, equip them with an smart flush-mounted part and enjoy smart home features without having the front plate replaced.
    Walli can work without battery
    There is also a * and ** in the text which refers to the specifications and configurator.
    controller is greyed out when you select the gira. ?
    well i have more useless devices on the shelve, i will add this one :)
    This hobby can get expensive fast :)
    I hate it when a compagny stated on the website, works with everything and then add a *
    and then somewhere else on that page: * no not everything
    *abuse* that
    well i found a place for it, just stick it to he wall, so we will never forget :)
