Support for Dahua IPC-C35
dlizak
Latest version of Yubii Home app should support Dahua cameras.
Actually I have Dahua IPC-C35 but there is no possibility to watch RTSP stream through LAN network on Yubii Home app.
There is only a spinner on the screen and about after a minute - message about "login error, check your login data blablabla...". Credentials are correct, as I can see JPEG snapshots.
If it will help to provide support in future Yubii Home versions, here is URL to RTSP stream:
/cam/realmonitor?channel=1&subtype=0
jpeg preview over local IP is different thing, to watch stream with the latest beta app you need to enable P2P in oyur cam settings and enter that data in the Dahua plugin
/monthly_2021_08/image.png.147429d8b1878fb1a931b2acd3aa1dc6.png" />
  • I don't have access to Dahua's Cloud and don't want to.
    My cameras are working locally, and I would like to use them by local RTSP stream.
    I use this plugin, but I've missed out the description. So... it works only with Dahua's Could.
    Thanks.
