disable all off?
Twannie
Hi
If you say "all off" to the Google (Hub)  it turns all light and switches connected with Fibaro off.
Can I disable this somehow?
Is it a "Google" thing or is Fibaro?
11 answers to this question
22 minutes ago, Twannie said:
Hi
remove "light" from dev prop.
and this device will not control lights
/monthly_2021_08/image.png.2eb3d005c65f78bacbf5cdee34e21425.png" />
  • i think you misunderstood
    Google turns everything off, so not only lights
    @Twannie can it be that your other devices are in the category lights?
    /monthly_2021_08/image.png.4916ca88c16f522b59e1a384a520dc66.png" />
    succes,
    //Sjakie
  • No they are not
    When I say "Google all off" it turns everything off so lights and other switches
    so actually Google turns the whole house off...
    I have a HC2
    Edited by Twannie
    /monthly_2021_08/image.png.e7dcb0acd59c20d42fed28f527a633ed.png" />
    Google all off is a master. command
    What about
    Google turn all lights off.
    Or
    Google Turn hallway lights off.
    Google turn all switches of.
    Google turn spesific switch off.
  • The issue is I do not want Google to react on "turn all off"
    Remove all your devices from Google, problem solved.
    Your saying turn all off it then google turnes all off,nothing we can do about that.
  • strange answer...
    Google creates the group (or what should we call it) "ALL" so I guess it is a Google limitation
    19 minutes ago, Twannie said:
    strange answer...
    Maybe place the devices that you dont want to disable in another group then "all" ?
  • Sorry there is no group "all"... just called it a group
    it is Google which collects all devices connected and reacts to "all"
