UI MEM /CPU
10der
Guys, what are you doing here?
/monthly_2021_09/image.png.07ce45ebef6a3a07b329ff0344b1d61c.png" />
memory - OMG
cpu near 100% - OMG
PS: edit qv
/app/settings/devices#preview-2323
  • new browser.
    mem OK
    CPU 102%.
    just SELECT label on UI
    /monthly_2021_09/image.png.4b22d9a0e9fb439c38f0e2d60e7106d0.png" />
    Working on optimizations as mentioned before, we are hoping that next version will boost things up a lot with lower CPU/Ram usage.
    Michał
    Michał
    I probably should not ask this... But any ETA ? ?
    Next version is focused on stability and performance improvements - it will be available sooner than typical version. I can't give you exact ETA though.
    We have pinpointed some thing which are crucial for you guys and want to fix all of them before releasing this one - of course we won't satisfy all users with this one but we will try to do our best.
    • Thanks 4
    Hi @m.roszak will it be possible to fix the satel icons in next version? they're broken since more than 6 months now.
    I can leave without but having them back would be cool :)
    Thanks for all info you're giving and thanks in advance for the satel icon fix !
    i have the same Problem with high memory usage (80-95%) so das UI is very very slow......
    Tryed differend browsers, all the same....
  • Please login or register to see this image.
    /monthly_2021_09/image.png.8f1cf35c02805671a05ab44d821f3744.png" />
    OMG again
    just want to edit values
    Yes, it is as slow as ?
    I had to reconfigure a smoke sensor, took me two hours. What a wast of time. I hope Fibaro will come soon with the release that solves the slow user interface. Until that time, I try to avoid the HC3 as much as possible.
          Had the same problem. At least for my setup, I discovered that filtering the devices in Settings grid to have only the one I need to edit  (or a handful of them) makes the interface responsive again.
          Not ideal but allows me to get things done.
    Ezequiel
    memory - OMG
    cpu near 100% - OMG
    PS: edit qv
    Some spoilers...
    System with more than 1500 devices on it.
    I am really hoping that all of you will be satisfied ?
    • Like 3
    • Thanks 4
    4 hours ago, m.roszak said:
    Some spoilers...
    impressing! but > 1000 similar devices ( like binary switch ) can be not relevant to real system.
    when this version will be available for real testing ?
    I can put there 1500 devices with differend types, it will result with some additional memory load but interface will be responsive as well.
    This is just an example, I just hope that all od you will be just happy with the performance of the interface in next release.
    You will be able to check it out yourself pretty soon I hope ;)
    tested with .493 and 1000 different mock devices, and indeed i can wait 30sec+ per click hehe, so whatever you guys changed in .529, it's really fast!
    We have put a lot of work in the matter of performance but next release won't contain everything we want to do - some things will need to wait for another release.
    This version mainly improves Dashboard and Settings -> Devices pages, of course there are some improvements in overall performance but please do not get frustrated if there will be some parts in the interface which still need some work.
    • Like 4
    /monthly_2021_09/image.png.e65711fe85a3cd1432823ec706c2457f.png" />
    @m.roszak Dear sir I hope you dont wait to long!
    This morning HC3 memory usage 53%
    Suddenly I see at 13:20 HC3 restart when I open
    Verry wierd it jumps so high I never have seen it on my HC3!
    Common HC3 error some where.
    So curious why it happends now and not in the passed days?
    //Sjakie
