UI MEM /CPU
10der
On 9/23/2021 at 5:56 PM, m.roszak said:
Thank you for your feedback @m.roszak.  2 or 3 version back i've installed the satel plugin from scratch on a spair new HC3 and the issue was still there. Maybe it has been fixed but the db is now corrupted (?).
I'll contact the support to check.
If you were installing unofficial versions between db migration scripts probably did not run ;)
EDIT:
This screen is from new version (unreleased).
if unofficial = beta then yes i'm installing betas if you're talking about alpha test versions then no don't.
Well if i catched you well, it should be ok with next version, cross fingers ! :)
Thanks for all your feedbacks @m.roszak
