French-CF 0
I'm using Heat ACtivator plugins (associated with several FGT0001), everything works well.
I have a minor problem to solve : when rebooting HC3 turn this plugin automatically On : which is good and logical... except in summer time as I do not want to start heating sys.tem for few hours when it's a bit chilly in the morning.
I have created a global variable that I set manually on heating on (winter) / heating off (summer)... I would like to code a Lua scene to test this variable every restart of my HC3 and turn off this plugin if this variable is on "heating off"... unfortunately none of command line I tried produce effect (e.g. : fibaro.call( plugin id , 'TurnOff').
Any suggestion to make this happen? Is there a specific command line to turnoff a plugin?
Best regards,
Cyril
