QuickApp with TCP loop issue
cashe
Hi!
Trying to get info from TCP device using well-known functions combination:
:connect() -> :waitForResponce() -> :onDataReceived()
But I've got an issue. While I'm editing QA code or just having the Edit window opened it is all ok. But when I closing it, the data from QA is stoped to fall after some time (~ 10 minutes). When I go to my QAs Edit window again, the QA seems to restart itself and data flow is back.
I've even recorded a video with this issue.
What I am doing wrong?
I am using HC3 Lite controller with the last firmware installed.
Thanks in advance.
Edited by cashe
6 answers to this question
that is “normal” behavior. Start editing will restart the quickapp.
Perhaps the quickapp just crashes after 10 minutes. There you have to look for the reason.
    If QA crashed, it should restart itself every 1 minute, isn't it? Moreover, no error message was received.
    It should restart first when you re-save it again.
    Is it just the log messages that isn't logged out to the console? When it starts again, it seems to be a time gap 22:56:.. 22:59:...  is it also a time gap in the expanded (full screen) log window?
    Sure, but it restarts exactly just after I entering the QA Edit mode, not when Saving.
    Here the LOG. When I entered the Edit mode, onInit was triggered.
  • Seems, I have fixed an issue.
    The problem was tcp socket sometimes can be closed or the destination was unreached causing QA to stuck.
    Moved
        self.sock = net.TCPSocket() -- creation of a TCPSocket instance
    from onInit() to the beggining of connect() routine and also replaced with
        self.sock = net.TCPSocket({timeout = 5000}) -- creation of a TCPSocket instance
    Thanks everybody.
    Yes, there is an issue that the socket is wasted and a new socket needs to be created if it's disconnected due to an error (read/write)
