hysteresis code. for example for thermostat
hater
subj
(c)
Edited by hater
  • hater changed the title to hysteresis code. for example for thermostat
  • Please login or register to see this code.
    Edited by hater
    Edited by hater
  •         -- don't use the current reading but average it out over
            -- the past <SMOOTH_FACTOR> readings (data smoothing) to get rid of noise, wrong readings etc
    add some useful functions
    and add code improvements
    Thanks, this is very useful code and nice to have in the library.
    Another similar piece is to calculate a sliding average, i.e . give me the average of the last 10 values. It gives a smoothed value instead of a jumpy value , like power measurements usually are.
    Normally we do this by saving the n last values and return the average of this - the problem is that we need a buffer and recalculate the sum.
    There is a neat trick without a buffer of values that is not exactly a sliding average but a good approximation.
    What we do is that we deduce the average from the current sum before adding the new value. (we only need to keep track of n and sum)
    Jan, and thank you, as well, it's your school :)
  • Jan, btw. another minor problem.
    smoothFilter like your or my monster ? smoothFilter do not guaranty with satiation below
    10:20:00 15*C
    [no data from sensor]
    11:00:00 11*C
    in this case we should ignore to use smoothFilter cuz accumulating data with different time is tricky, IMHO
    2 hours ago, hater said:
    able to reset, @jgab
    Alternatively
    2 hours ago, jgab said:
    Alternatively
    Nice function
    It could be perfect to have similiar function for moving average (where is also time how long values inluence final number)
  • 2 hours ago, petrkl12 said:
    moving average
    On 10/24/2021 at 2:22 PM, petrkl12 said:
    Nice function
    Yes, but to use the same trick (approximation without buffer) it would be easiest if the value was sampled at regular intervals.
    Like this:
    Otherwise a buffer is needed and re-summing for every average calculation...
    warning.
    setInterval in ms NOT min.
    so pay attention mul on 1000
  • and then some.
    IMHO
    1) do not need to push the same value to function. only if value a new one according to stamp from device
    2) we should use stamp from function fibaro.get
