SmartHomeEddy
This QuickApp monitors your Solax managed Solar Panels
The QuickApp has (child) devices for Solarpower/m², Today production, Total production, Total Power to Grid, Total Energy to Grid, Energy from Grid, Total Power/m², Battery Energy, AC Power R, AC Power S, AC Power T, Battery Power, Power DC1, Power DC2, Power DC3 and Power DC4
The rateType interface of child device Today Energy is automatically set to "production"
The readings from the child device Today Energy will be shown in the new energy panel
The readings from the child device Total Energy is automatically set to the right Wh unit (Wh, kWh, MWh or GWh)
See API documentation on
User can get a specific range of information through the granted tokenID. Please obtain your tokenID on the API page of Solaxcloud for free.
The tokenID can be used to obtain real-time data of your inverter system. The obtain frequency need to be lower than 10 times/min and 10,000 times/day.
Version 3.0 (19th February 2023)
  • Changed the descriptions of the Solax Cloud values
  • Converted the feedinpower value from positive to negative or from negative to positive
  • Added translation for English, Dutch and Portugese
  • Added child device for consumeenergy
Version 2.1 (4th December 2022)
  • Prevented almost empty responses like these: {"success":false,"exception":"Query success!","result":"this sn did not access!"}
  • Added log text to main device if no data from Solax Cloud
Version 2.0 (16th April 2022)
  • Added Child Devices for feedinpower, feedinenergy, consumeenergy, feedinpowerM2, soc, peps1, peps2, peps3, batPower, powerdc1, powerdc2, powerdc3, powerdc4
  • Added all values returned from the Solax Cloud to the labels
  • Changed all the device types to the most current ones
  • Changed the handling of bad responses from the Solax Cloud
  • Replaced null values in responses with 0.0
  • Optimized some code
Version 1.0 (17th November 2021)
  • Tested, ready for release
Version 0.2 (15th November 2021)
  • Changed json response
Version 0.1 (13th November 2021)
  • First (test) version
Variables (mandatory):
  • tokenId = token ID of your Solax Inverter, obtain your tokenID on the API page of Solaxcloud for free
  • inverterSN = Unique identifier (Serial No.) of your Solax inverter
  • solarM2 = The amount of m2 Solar Panels (use . for decimals) for calculating Solar Power m² (default = 0)
  • interval = The default is 300 seconds (5 minutes), the daily API limitation is maximum 10 times/min and 10,000 times/day
  • debugLevel = Number (1=some, 2=few, 3=all, 4=simulation mode) (default = 1)
/monthly_2021_11/solax_icon_transp.png.f9c734692fbdaca53d5e05ad76976073.png" />
API items: Description (Accuracy) (Unit)
  • inverterSN: Unique identifier of inverter (Serial No.)
  • sn: Unique identifier of communication module (Registration No.)
  • acpower: Inverter.AC.power.total (1) (W)
  • yieldtoday: Inverter.AC.energy.out.daily (0.1) (KWh)
  • yieldtotal: Inverter.AC.energy.out.total (0.1) (KWh)
  • feedinpower: Grid.power.total (1) (W)
  • feedinenergy: Grid.energy.toGrid.total (0.01) (KWh)
  • consumeenergy: Grid.energy.fromGrid.total (0.01) (KWh)
  • feedinpowerM2: Inverter.Meter2.AC.power.total (1) (W)
  • soc: inverter.DC.battery.energy.SOC (1) (%)
  • peps1: Inverter.AC.EPS.power.R (1) (W)
  • peps2: Inverter.AC.EPS.power.S (1) (W)
  • peps3: Inverter.AC.EPS.power.T (1) (W)
  • inverterType: Inverter type, details refer to Table 4 in appendix
  • inverterStatus: Inverter status, details refer to Table 5 in appendix
  • uploadTime: Update time (format 2016-10-26 17:33:01)
  • batPower: Inverter.DC.Battery.power.total (1) (W)
  • powerdc1: Inverter.DC.PV.power.MPPT1 (1) (W)
  • powerdc2: Inverter.DC.PV.power.MPPT2 (1) (W)
  • powerdc3: Inverter.DC.PV.power.MPPT3 (1) (W)
  • powerdc4: Inverter.DC.PV.power.MPPT4 (1) (W)
Download the QuickApp here (download the file and un-zip):
or from the Fibaro Marketplace:
How to install:
  1. Open the Configuration Interface
  2. Go to Settings > Devices
  3. Click  +
  4. Choose Other Device
  5. Choose Upload File
  6. Choose file from your computer with .fqa
Edited by SmartHomeEddy
added. if i use , than value return to 0. i have now 2094 x 1038 x 13panels = 28.256436 m2
  • It is the Solar Power/m2 that gets calculated. The Total Power/m2 comes from the Solax Cloud and apperently is empty.
    if i call API comand on browser total m2 is 0 too.
    /monthly_2022_04/923298558_apisolax.jpg.deab589214d312608d4e41c289f67312.jpg" />
    I think the Solax Cloud doesn’t knows your m2 amount. Maybe you can edit it in the Solax Cloud or your installer can.
    i have acces to basic, advance and meter settings. i cant find any setting for numbers panels or m2
    Hi all,
    I hope all doing well
    I have a question about my Solax inverter SK-SU 5000E/48V, do you think it will be intrgrated with my hc3 by using this quickapp?
    thank you for your help
    Regards
    Lahoucine.
  • You need two items to have it working:
    If you have those, you could check the Solax Cloud with this URL (fill in the tokenID and inverterSN)
    tokenId&sn=inverterSN
    You should receive an answer like this:
    Hi Eddy,
    Thanks for this quick app.
    I'm getting an error with the QA, if the Inverter I get an error with the QA when the inverter is off overnight or in Wait Mode. When the inverter is online, everything works perfectly.
    [29.11.2022] [23:44:01] [ERROR] [QUICKAPP494]: QuickApp crashed
    [29.11.2022] [23:44:01] [ERROR] [QUICKAPP494]: main.lua:386: bad argument #2 to 'format' (number expected, got nil)
  • Hi @RudyT
    Thanks for reporting. I made some changes. I don't have the Solax Inverter, maybe you could do some testing with the new code? I will send you a PM.
  • A new version of Solax Monitor is available.
    Thanks @RudyT for testing
    Hello!
    I need some help understanding whats wrong with this readings, in the dashboard i'm getting this values (wich are correct, since at this moment im producing 1046W and consuming around 600W (not using nothing from the grid)
    But in the APP what i´m getting is that im consuming 1.42. From where its getting this value?
    Edited by JokkerPT
    Sorry, I wasn't clear, I meant the Homecenter 3 firmware. In the latest firmware version you are able to setup in the advanced settings of your devices, if the value should be used in the power measurement: "Use instantaneous power in Energy Panel calculations"
    Look at all your devices to mark or unmark this setting to get the right reading in your Yubii app.
    I only have 1 device that could give me higher values of consumption (that only works at nigth), the other ones are residuals.
    For example rigth now im getting this different readings
    /monthly_2023_01/image.jpeg.ad6a2652db08c9f6dda5d5b97b978176.jpeg" />
  • Which devices do you use for your energy panel (kWh) and instantaneous power (watt)?
    Only 4 are normally used (1 Switch and 3 ligths) but the switch is the only one used at nigth.
    /monthly_2023_01/image.png.99d4a117445a364da2b59a553c2bfdef.png" />
    On the cloud of fibaro, i see that the value of Grid power is normally correct, but on the yubii APP the consumption value its almost always higher.
  • A new version of the Solax Monitor QuickApp is available.
    Please use the .fqa file and replace your old QuickApp with a new one.
