Dimmer 2 not showing brightening in HC3 anymore?
hellkert
I have installed Fibaro Dimmer 2 in my house and yesterday in HC3 the preview + dashboard had functionality to turn on/off and brightning the light.
But today, I can only toggle on/off. What has happened? It is not only one dimmer, all dimmers having limited functionality.
1 answer to this question
Have you tried a reboot of HC3? Check the advanced parameters to make sure that dimming is still permitted. Also turn off automatic calibration just in case.
Did you do any upgrades recently? Roll back if so.
If those all fail, try restoring a backup.
