QA InfluxDB2
petrkl12
QA for regular exporting data from HC3 to InfluxDB 2.x
30 days trial period - than you need license key: 30EUR via Paypal account
For license key I need your HC3 (or HC3L or Yubii) serial number: HC3-xxxxxxxx
Ideally include your device serial number and QA name in the payment note.
QA is sending data based on events and also in regular intervals from HC3/HCL/Yubii to InluxDB 2.x. It generates data to Influx with minimum delay.
There is data about HC3 system (cpu,ram), info about scenes (start, stop), geofence events and a lot of details about devices. In QA variables there is possibility to define include/exclude measurements/IDs/… (default all data are sent to Influx)
QA:
Icon:
/monthly_2022_02/InfluxDB.png.b9f88eff9645ffa375849b159f905636.png" />
QA variables - you have to setup -
IP_InfluxDB2 ie. 192.168.1.111 (or server/database address without https:// or http:// )
Port_InfluxDB2 ie. 8086   (for cloud database usually 443)
HttpType ie. http     (defaul value http, for cloud usually https)
Organization ie. YourOrganizationFromInfluxDB2
Bucket ie. YourBucketFromInfluxDB2
TokenAPI ie. YourTokenAPIFromInfluxDB2
Edited by petrkl12
  • Like 6
  • 2 hours ago, Fabir said:
    @petrkl12Still no luk in my case.
    How can your QA write data into the cloud influxdb, without knowing the user name and the password from influxdb cloud?
    I don’t use cloud database so maybe @PSi could explain it …
    @PSiHi, great the new QA is working for you. In my case no luk so far.
    Could you explain or show an example how to setup the inluxdb cloud in order to work with the QA?
    Thank you verry much in advance.
    sure, this is my config:
    hostname without https-prefix
    Port 443
    HttpType https
    all other params similar to locally hosted instance
    You can test yourself here for free:
    @PSiThank you for the quick response.
    I already have a free cloud influxdb account.  Bud I'm new to the influxdb. I never had it locally in the LAN.
    This is what I unterstand so far about influxdb Cloud. Please correct me if I'm wrong.
    I need to create a bucket and an API Token.
    The data from fibaro hc is stored in the bucket.
    Which API Token should I choose? There is All Access API Token and Custom API Token
    How can the the QA write data to the influxdb Cloud, without knowing my account name and password? Or is this erverthing done by the Token.
    Thank you a lot
    Thank you a lot
    Hey,
    you create an Org on start and assign a Bucket.
    Then create an API Token with access to this bucket, AllAccess is also fine.
    The combo org, bucket and token manages your access.
    If needed, get a free grafana instance from
     to visualize your data, a connector for influxDB is present
    @PSiHi, thank you for your help, still no luk here with the cloud influxdb. It sems the QA is trying to write data to the influxdb cloud. I see the same send errors as you have postet on 1. February.
    About the path/IP adress for the cloud influxdb. I'm using the start address from influxdb cloud. This looks like below:
    ????? stands for a long alfanumeric number
    Or do I need to use the path where the buket or the api token is in the cloud?
    Hi, just use this for IP_InfluxDB2:
    europe-west1-1.gcp.cloud2.influxdata.com
    I used AWS instance eu-central-1-1.aws.cloud2.influxdata.com , your Instance is hosted on GCP but it should also work
    Edited by PSi
    @PSiHi, thank you very much, this did the trick.
    Now I have data in the influxdb cloud. Could already make some dashboards in influxdb cloud. But the dashboard features in influxdb cloud seems to be quite limited.
    I would like to have the dashboards in the grafana cloud.
    Now trying to get data from influxdb cloud to the grafana cloud. No data so far. I have to read the doku and try again.
    Hi, You can easily add InfluxDB with Flux Query language in Grafana Cloud.
    Needed params are Org, Token and Bucket
    I was not able to configure a connection with InfluxQL
    @PSiHi thank you again for the tip. I will give it a try
  • New version in first post.
    I've been using this QA for about a year now. I can say it is rock solid, performs
    perfect. And gives great insight in the data that is important for me.
    Latest addition for me is,  air quality and humidity control for my fan system.
    Edited by ppeterr
    Hi @petrkl12, the payment method is working yet (paypal)? It’s a lifetime licence?
    thx,
    Tamas
    Yes, you can there also pay via MC/VISA cards
    Yes, license is connected with serial number of your device (HC3/HC3L/Yubii)
    Ok, i sent a money to you with HC3 serial. A love your work.
  • Thanks, you have license key in PM
    Super, works fine… thx!!!
    @kjt Looks great, i like the blue theme, stylish. I'm using grafana, a little more options i think, but still your dash looks good!
    @petrkl12Hi last week I've payed 20 Euro to you paypal account for the influxdb QA licence. When could you provide the licence Key?
    could you send me via PM your email address?
    I have sent already to email: [email protected]....
    Edited by petrkl12
