RoReAl 2
I run a AC as a heat pump in my garage. I want it to run att "FP" mode and that means frost protection. The AC then runs att lowest heating temperature 8°C.
The Quick app does not support this mode, when in FP mode the QA gets no reply from the Sensibo Sky on line 494 (string return nil) an the QA crashes.
Does anybody have the same problem and /or know a work around this problem?
[2022-02-17] [11:36:07] [ERROR] [QUICKAPP930]: QuickApp crashed
[2022-02-17] [11:36:07] [ERROR] [QUICKAPP930]: main.lua:573: bad argument #1 to 'sub' (string expected, got nil)
