Neo Andersson 143
Dear Fibaro superusers
May I kindly ask for some real support here.
We are installing Fibaro systems, and all of my customers are coming bak to me with the same problem.
Radiator valves from Danfoss (POPP) are loosing connection after the battery got replaced. Every single valve acts the same way.
Before the battery replacement, all of them were working properly, only after the battery relpacement they started to loosing connection.
It is not constant loss, but they catch the signal for some minutes then they loose it, and it gooes like this.
Probably that's why the device is not reporting the correct values at corret times, so the scheduled heating plans are worht to nothing.
I have tried everything what i could. Soft reconfigured the device, reconfigured the mesh network, rebooted HC3. Nothing works.
Very frustrating, an even more frustrating for the customers, as it happens in winter time.
Does anyone have any similar probelms, and could solve it somehow please?
9 answers to this question
