goteDeath 0
Hi
I'm looking to set up smart switches throughout my house and I would like essentially all of my lights to be dimmable.
I'm from Australia and it seems like I'm very limited in my choices for smart switches that have the appropriate certification for use here. Especially because I do not want wifi ones.
I also do not want to have many dimmer smart switches, one for each circuit, as that will take up a lot of wall space and look ugly. But I cannot find any smart switches that can dim multiple circuits.
I found a zigbee smart switch that goes up to 4 gangs for just on/off that I'm likely to go ahead with. And I'm thinking of installing the Fibaro Dimmer 2 behind these switches (or in the roof space if I need multiple Fibaro Dimmer 2's installed and they don't all fit behind the switches), one for each light circuit connected to each of these switches.
Can someone please confirm if this approach works? I'm not very familiar with these products so I just want to make sure my understanding is correct before I buy a whole house worth of the Fibaro Dimmer 2's! I've tried searching all over the web but every example I read about is about installing the Fibaro Dimmer 2 behind a normal, non-smart switch...
Thanks for the help!
4 answers to this question
