too many notifications with low batteries
jjacques68
With previous and with this update, we are currently, 2 users, with to many notifications about low battries...
I receive up to 5 notifications a day, for one device.
So now, I disabled all notifications for low batteries :(
And check manually with a QA...
If someone have an idea ?
best regards.
Edited by jjacques68
  • jjacques68 changed the title to too many notifications with low batteries
You can disable the notification from the child devices, and leave only one notification of the main device active. And you can set the interval to “once”.
  • yes I tried that.
    Just setting the parents and disable the child...
    But the problem still persists.
    And the interval was well on "once".
    I don't understand all
    In the web interface :
    In the API :
    /monthly_2022_04/image.png.6f436e448bf5c7c739bae17f90d2bd9d.png" />
    (and I refresh my browser :)...)
    and where are the settings for the interval, the channel ??
    That interval is the “once” thing
    Where, in the API, of course...
    I wrote a scene, in 2020, to disable all notifications - then installed sankotronics battery scene.
    That scene might answer your question about the API, but I might have misunderstood your question.
    Hi all -
    this is only partially related to this topic, but is there a way to clear all notifications in the notifications panel ? I have hundreds upon hundreds of them, most of them being battery-related, and the only way to clear all of them is to clear on a per-day basis - which would likely take me hours given the backlog.
    I would be baffled to see Fibaro hasn't implemented any way to clear all notification, as in ... basically ... any other app out there ?
    This will clear history:
    //Sjakie
